Ran my car at the track. Times inside!!
Old May 3, 2004 | 09:22 AM
89305RS's Avatar
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
Well it suprised the hell out of me. Heres the slip. I thought it would have been slower.
R/T -.063 (redlight)
60' 2.322
330' 6.579
1/8 10.105
mph 70.13
1000' 13.20
1/4 15.675
mph 87.64
Well here are my mods:
305 TBI
open K&N
injector spacer
open rear w/2.73 GEARS!!!! not a mod
new 700r4 with B&M shift kit and corvette servo(hell of a 1-2 shift)
225 70 r15s
and no cat.
Next week the posi 3.23 goes in. Ill keep all of you informed what the before and after times are. Im also going to put my cat on and take the rest of the exhaust off. It sounds awesome.
Old May 3, 2004 | 09:23 AM
89305RS's Avatar
Oh yeah its also supposed to have an LT-1 cam but im not sure on that.
Old May 3, 2004 | 09:47 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
WOW sounds like its runnin damn good man keep it up and let us know how the rearend works out for ya
Old May 3, 2004 | 09:50 AM
89305RS's Avatar
That i will general. Hey where in illinois are you? I race at cordova and sometimes byron.
Old May 3, 2004 | 08:49 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
damn not bad but i did notice your 2.3 60 foot. with some desent tires that should be down to like a 2.1-2.0 but still not a bad slip at all
Old May 3, 2004 | 10:06 PM
THEGENERAL's Avatar
im in staunton illinois...its down south of you ..our closest race track is at gateway international raceway ....in madison illinois ...
Old May 3, 2004 | 10:20 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Good time, especially with that '60. If you really think there is an LT1 cam in there, then some chip tuning may do wonders.
Also, I'm near joliet IL. I should make it up to Byron sometime this year, and am headed down to visit a buddy in st louis in about a month, and plan on making it out to gateway. Hope to see ya guys.
89305RS-I should have the 383/ T-56 combo back together by july-hoping for a low 12-high 11, but it all depends on if I can get the 12 bolt in there by then.
Old May 3, 2004 | 11:06 PM
THEGENERAL's Avatar
awsome r90camarors let me know when your goin to gateway and ill try and meet up with ya down there ...sounds cool man good luck with the 12 bolt
Old May 4, 2004 | 07:42 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
what is interesting, is how low your trap speed is. i was running the just a hair faster ET, but my MPH was in the 90 range, and i had better 60'. you may want to look into where you trap speed is going, it is possible you are either, shifting too early, or are lossing power up high. i was guess with the LT1 cam in the car, you should be trapping above 87mph.
Old May 4, 2004 | 07:59 AM
89305RS's Avatar
2.73 gears dont make for a very high trap speed. Or a great 60' time either. Today the 3.23 posi rear goes in Thatll bring a good 60' and trap. Im guessing with the new gears a 14.7 hopefully. The car shifts at 5000 in 1st and 4800 in second. Im really looking forward to geeting the rear in tonight!! Well see what it does friday!! Plus its posi so ill have a great 60' the peg leg 2.73 in there now wouldnt even squeal the tire off the line. I HATE 2.73s!!!!!! the guy that i bought the car from (mtchevy1) said the car had the LT-1 cam.
Old May 4, 2004 | 01:24 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I dont think that those gears are gonna knock .9 off your times. I would say like .3. Youll probably be running around a 15.3 or 15.4. Good times for an auto Lo3 though. Keep us posted.
Old May 4, 2004 | 01:56 PM
89305RS's Avatar
I went from a 3.08 to a 3.42 in my S-10 and dropped from a 16.1 to a 15.0 so i bet it does.
Old May 4, 2004 | 01:57 PM
89305RS's Avatar
The funniest thing was that there were like 4 irocs running 16.0-16.2. They were like WTF?? I was laughing at them. I think they were 305s though.
Old May 4, 2004 | 06:47 PM
Engine: LO3;383tpi
Generally, gears won't help trap speed too much, but will improve ets. I think .9 seconds is a little unrealistic in an f-body, but with a stall, I think .5 is a good estimate.
Also, are you sure your tach is correct? Factory tachs suck, and often read higher than actual rpm. Also, with an LT1 cam, you'll want to manually shift at a higher rpm- I think 5,500rpm outta first, and 5,300rpm outta second would be a good starting point
Old May 5, 2004 | 06:18 AM
Dewey316's Avatar
Car: 1990 Camaro RS
i went the other direction. 15.7 - 15.9 with the gear change.
Old May 5, 2004 | 08:01 AM
89305RS's Avatar
r90camarors, I have an autometer tach along with my stocker. They both read dead on the same. My tach is accurate. But my s-10s tach was off like 300-400 rpms. Factory sucks. Im having problems geting the old rear out of the car. 20 years of rust make it hell pulling that thing out. Any ideas on how to get it out would be appreciated!
Old May 5, 2004 | 04:11 PM
Z28GEN3's Avatar
saturate the bolts with a PB blaster or WD40 and then tapping it w/ a hammer, if the dont work you could try heating the bolts up with a torch. when all else fails you could just grind the bolt heads off or torch em off.
Old May 6, 2004 | 08:04 AM
89305RS's Avatar
I got them off!!! W00T! Well i guess my hammer wasnt big enough
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Kaweh
Aug 9, 2015 02:54 PM
