TPS = .60@Close Good?>
Old May 12, 2004 | 10:21 PM
Sims's Avatar
Car: 89 S-10 Blazer
Engine: 4.3 V6
I checked my TPS today, at closed its sitting at .60 - > is that enough to cause it run off? Or is that close enough to be ok? I check the curve and it tops out around 4.6ish and is quite steady.
TIA!
Old May 13, 2004 | 06:19 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
its a hair high, ideal is .54 i don't think i would worry about that too much.
Old May 13, 2004 | 08:26 AM
Sims's Avatar
Car: 89 S-10 Blazer
Engine: 4.3 V6
I'm still surging a bit at idle and running a bit rich. Likely the IAC not handling the new cam I think. But now that its not 20* retarded its waay better lol. Amazing that!
Old May 13, 2004 | 08:28 AM
Dewey316's Avatar
Car: 1990 Camaro RS
amazing eh
what cam are you running, if you still have the stock chip, you are likely going to run rich at idle no matter what.
what did you set your timing to? i would guess that somwhere between 4* and 6* advanced with the ESC disconnected, is going to give you the best results.
Old May 13, 2004 | 08:55 AM
Sims's Avatar
Car: 89 S-10 Blazer
Engine: 4.3 V6
Originally posted by Dewey316
amazing eh
Comp Grind 266HR
Gross lift .500/.500 gross
Duration 266/270 advertised - 210/215@0.50
Lobe Seperation 112*
yeah timing is about 5* Advanced now.
Old May 13, 2004 | 09:31 AM
Dewey316's Avatar
Car: 1990 Camaro RS
well, that isnt' all that big for a 4.3, since it basicly a 350, minus a couple of cyls.
i would say 5* is about where you should be set, you really should look into prom burning, really that motor is never going to run as good as it could, without you tuning it right.
Old May 13, 2004 | 09:38 AM
Sims's Avatar
Car: 89 S-10 Blazer
Engine: 4.3 V6
yeah I've got a guy in town that does ODB1 Tuning but I want it "finished" before I get that done -meaning getting the holley TBI on and working, and getting the headers/exhaust redone so that I only need it chipped once.
Also looking into scooping an ALDL cable off ebay to do some datalogging and see whats going on.
I believe the gross lift on the stock cam is about .357 as opposed to .500 for the comp so its a bit of a difference
Old May 13, 2004 | 10:12 AM
Dewey316's Avatar
Car: 1990 Camaro RS
yeah, just knowing the spec diffrences, i can tell you it is going to need less fuel, and more timing at idle, and alot more fuel up high. without a chip there is no real good way to do that.
Old May 13, 2004 | 10:34 AM
Sims's Avatar
Car: 89 S-10 Blazer
Engine: 4.3 V6
With the logger what kind of values should I be looking at to see if my a/f mixture is good all the way through the run to WOT? I dont need it leaning out at higher RPMS.. I think the Holley 670 should help out with that.
Old May 13, 2004 | 10:39 AM
Dewey316's Avatar
Car: 1990 Camaro RS
no it will not help out, because the computer contorls how much fuel is added. if anything, it will make it worse, since more air will be going into the engine.
read the tunning intros. basicly, start at idle and part throttle, look at the BLM data. once you have BLMs sorted out, the work your way up to WOT runs, once you go into PE mode, you will only have the o2 values to go off of, shoot for around 900mv here, but the stock o2 is VERY inacurate. once you get them all around 900mv, i would try to get on a dyno with a wideband, and then you can really tune WOT.
there is alot involved, and a very steep learning curve, i would suggest reading all you can in the DIY-PROM board, read all the tuning intro's at the top of the page.
Old May 13, 2004 | 10:58 AM
Sims's Avatar
Car: 89 S-10 Blazer
Engine: 4.3 V6
thanks, I've been doing some reading on the DIY Eproms, very complicated stuff lol. But I'm willing to learn. Man this internal modding is fun stuff
Old May 13, 2004 | 01:31 PM
Ronny's Avatar
when my fuel curves were in line(data logged/burned 20 chips) the WOT or PE was spot on at WB02/dyno run. commanded 12/1 and dyno run showed 11.9/1 and 12.1/1. i might add i disabled PE (not recommended) to get higher rpms in line(fuel table) and ones that did not populate i kinda guessed and enrichened on safe side. also i swapped out injectors and went to the biggest 90's. started tuning 6/2003.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
