no power
Old May 13, 2004 | 12:11 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
no power
Ok hears the problem over the past 6 months the car has had low power it starts to give up a 3500 and sputters at 4300. I have a new coil, cap, plugs, o2 sensor the injectors spray good and I notices a taping coming from the right side of the motor so i readjuster the rockers but it is still there. could it be the holley intake i put on after that the power was gone? Its the 89 if you look at the sig
Old May 20, 2004 | 11:22 PM
fbodyandy's Avatar
is the egr the source of the tapping?
Old May 20, 2004 | 11:25 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Shouldn't be. Check the fuel pressure at the feed line. Even when my fuel pump went out my injectors could still spray the dying 6psi evenly.
Old May 21, 2004 | 12:23 AM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Check your timing.
Old May 21, 2004 | 12:24 PM
Engine: 5.8
I have no egr, I will check the fuel pressure and the timing is at 3*. I put wires on it and it runs good but still not happy, it's ben dieing on me allot and I don't know why?
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
