91 firebird 305 tbi vin e, which pump?
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
190 or 255 gph walbro? can the return handle the 255?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Go with either. If you are worried that your stock regulator cannot keep up than go with the 190. I know people who run both and neither of them have any problems. The regulator problems associated with the 255 are few and far between. The 190 will still support more power than your 305 will ever make.
Car: 04 Xtreme Blazer
Engine: 4.3L V6
in response to this, If I put the 255 in my TBI car now, and go TPI later, I will have the right fuel pressure now(approx. 13 psi) and the correct pressure(45 ish) later, right?
Car: '90 RS
Engine: 377 LSX
Engine: 4.3L V6
Originally posted by ShiftyCapone
Oh yea. You will be pushin' upwards of 60 PSI. The 255 can support a multi port set-up up to 800hp.
Car: '90 RS
Engine: 377 LSX
so the TBI regulator would knock the high pressure down to the right psi?
Car: 2002 Z28
im going with a 190 this summer cause i dont want to deal with the potential problems of the 255. Not saying that it will cause problems but i have read were people are having problems keeping the fuel pressure down, and i dont think ill be going to TPI anytime soon.
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i got the 190 pump recently and its gogin in june 6th. I wanted to be safe and know the stock regulator can hadle the extra psi. i building a 355 motor besides and if you every do this your gonna need a better pump.. i got mine fomr the site below. it was around 88 for the kit shipped to my door and i got it in 2 days.
http://www.autoperformanceengineering.com/
Car: 1988 Camaro IROC-Z
Transmission: Borg Warner T5s
Could someone give me a direct link to the 190 pump for camaros? All I can find in the 190 version is for imports and Mustangs.
Also another quick off topic question, I am looking for a TB spacer to raise my open air element off the distributor. Now I hear that wood and other composits are better then aluminum because they contuct less heat. My question is that how do those hold up over time? All that fuel being sprayed around that wood has to break down the wood wouldnt you think?
Car: 91 RS
FPG001 - $83
a.k.a. GCA701
is the pump...
its under the heading
'85-'92 GM Universal
parts
notes
no more 'M' pumps
LT1 owners, read this
if im remebering correctly you click on the left side under fuel pumps on intake applications then looking for the above .
there phone number is 866-383-5786 if you cant find it on the site. then you can give him the model above.
a.k.a. GCA701
is the pump...
parts
notes
no more 'M' pumps
Car: '90 RS
Engine: 377 LSX
well i have an aftermarket regulator , im runnin 16 psi now, maybe why i need a pump......anyways if the 190 will support up to 600 hp then i gather thats all i need.........btw, what is the stock pump pressure and what is the 190 pressure?
Car: 2002 Z28
http://www.autoperformanceengineerin...ump.html#pumps
stock pressure is between 9-13psi, and with a 190 pump it will more likely stay at 16psi since that it was your are currently at.
no , i mean im 16 psi at the throttle body, but what is the stock pump rated..........i know tpi are around 40 i think, i was curious what the stock tbi fuel pump is rated and what the 190 gph walbro is............
Car: '90 RS
Engine: 377 LSX
huh, i put an inline gauge in where the fuel filter is and with my pressure regulator screw in as far as it will go it was reading 16.........how is this possible if the stock pump is 13 you say?
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I'm sure you could get it up to 16 at idle or just sitting there not moving. The problem is when you put the engine under load. I could almost guarantee you that your stock pump is not putting out 16psi under load, it probably drops off sharply when you get on the throttle. Try to set it up so you can see your gauge from inside the car while you're driving.
ok , i plan on doing that when i put in da nitrous
