Connecting PCV to Open Element
Old Jun 12, 2004 | 09:21 PM
James Montigny's Avatar
1992 Firebird 305 TBI
When I did the open element mod, I was left with a tube from the
passenger side valve cover just standing there.
Ever since then, I've had trouble with crankcase pressure poping
the PCV valve out of it's grommet on the driver's side.
I know K&N has these little adapters that fit between the
top and bottom plates of the air cleaner, and allow you to
connect that tube to it. Has anyone seen these? Or know where
I can find one?
- James
Old Jun 12, 2004 | 09:28 PM
ponykiller1992's Avatar
Car: 89 formula 350
Transmission: Stock 700r4
Are you talking about the breather? When I had my open element, I just got a tiny filter and hooked it to the tube that went into the AF housing.
Old Jun 12, 2004 | 09:32 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I assume you are talking about the filter on the rear of the passenger side valve cover? You can use any 3/4" push in breather.
Old Jun 12, 2004 | 09:34 PM
I've seen those, but what I am looking for looks like a small
peice of sheetmetal, about 1x3" that sits between the bottom and top of the air filter housing up ag ainst the filter (on the outside). It has a nipple on it to connect to a small hose, like
the one that runs down to the valve cover.
I saw one in a catalog at the autoparts store last year,
I should have bought it when I had the chance.
Been driving around with the open element for about 2 years now.
Will the breather solve my pressure issue?
Or is it completely unrelated?
Old Jun 12, 2004 | 09:38 PM
Car: 89 formula 350
I am confused as to what your are talking about, can you post a pic?
Old Jun 12, 2004 | 09:44 PM
This is the tube I want to connect to the air filter behind it.
Not so much for the filtration, but for the vacuum.
Old Jun 12, 2004 | 09:54 PM
Car: 89 formula 350
just put on a little filter, like this...
Old Jun 13, 2004 | 01:22 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Just pull the whole tube out of the valve cover and put a 3/4" push-in breather right in there. Works fine and cleans up one of the many black tubes on the passenger side.
Old Jun 13, 2004 | 07:14 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
THis is the easiest thing to do. If you want to do it even cheaper just wrap some filter gauze that is sold at any auto store around that tube and seal it off with a zip tie.
Old Jun 13, 2004 | 09:59 AM
Stock,
this tube is connected to the air cleaner.
Does anyone know why and what it does?
Old Jun 13, 2004 | 10:35 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by James Montigny
Stock,
It is just another crank case breather. It only ran to the filter housing so that GM could get away with one filter and not two.
Old Jun 13, 2004 | 07:52 PM
Akshay's Avatar
You wanna replace the PCV w/ a breather filter?
EDIT: Oh never mind. I re-read your post.
Old Jun 14, 2004 | 10:33 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Not exactly, the PCV valve is to keep it from building positive pressure, that is why it is a check valve, the side with the breather on it, should be at some point that will see a little bit of vacume. idealy you have some vacume in there, it will help with blowby and ring sealing.
Old Jun 14, 2004 | 11:47 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea thats what I meant. By two filters I mean the stock one in the air cleaner assembly and the little 3x2 inch one that fits right on the inside edge of the housing. The PVC is necessary. I didn't mean to confuse anyone by thinking it wasn't.
Old Jun 14, 2004 | 03:10 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
I just took the stock breather filter (the one that sits on the inside of the stock air cleaner houseing) with that stock tube and let it sit right up against my open element. It's worked great for a year now and I've never had any problems. It even kinda looks like it was supposed to be like that
Bruce (90RS305)
GTAman
Jul 3, 2024 07:29 PM
tglennon11
Sep 23, 2015 05:30 PM
scotrans am
Sep 5, 2015 04:26 AM
luvofjah
Sep 3, 2015 07:08 PM
Slush92RS
Sep 2, 2015 08:56 PM
