Initial TPS Setting
Old Jun 15, 2004 | 08:04 AM
1993GMCPU's Avatar
Car: TBI CHEVY, TPI 5.0 HO
Engine: 5.7 FIRST hp SMALL BLOCK, BIG BLOCKS!
Initial TPS Setting
Hi; I was told TPS should not need to be adjusted, but it has adjustments as far as screw down wholes and wondered if like on a Mustangi if there are adjustments to set TPS initially?
See Mustangi sample below:
Re: 1993 Setting TPS Correctly
Do you not have to a least set TPS as a starting point as follows, yes this is a Ford, but just an example hope it does not offend the Chevy Gods, :-):
1) Loosen the two screws holding on the TPS, (The screws can be very stubborn, so make sure you have a good quality screw driver that fits snug and has a long handle for lots of torque, or you might strip the heads) just enough to able to swivel the TPS with force.
2) Pierce the "GREEN" wire with the pin and hook the positive (+) lead from the voltmeter to it.
3) Ground the negative (-) lead from the voltmeter. Use a good ground, like the engine or other grounded metal source.
4) Turn your ignition key to the run position, but do not start the vehicle
5) Rotate the TPS until you achieve .98 to .99 Volts (For stock or slightly modified engines).
6) Tighten the screws on the TPS and recheck.
Old Jun 15, 2004 | 08:38 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
yes, the procedure is pretty similar, it should be at .54v with the throttle blades closed, and 4.0v or more at WOT.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
