no power below 2k rpm.
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
even with the ground wet if i punch it from a dead stop it will not break the tires loose until it 2k rpm then it just breaks them lose on the spot and will roast them until i let off the gas. any fixes for this? or is it just in teh timing table in teh computer?
anyone? how can this be remeided. its really annoying.
K&N Open Element
Flowmaster muffler(factory piping)
Smog Pump Delete
Timing was set at what apperead to be 0* so we bumped it up what we believe to be 6*. it is running much stronger now.
Smog Pump Delete
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Did you unplug the EST before you set the timing? When was the last time the car had a tune up. There could be a million reaons for sluggish performance.
yea we unplugged that. it runs much better.
with in the last 5k miles
new cap
new rotor
new wires
new plugs
new air filter
with the timing bumped it runs MUCHO better. no bog off idle.
Car: '90 RS
Engine: 377 LSX
theshackle
Sep 17, 2020 08:26 AM
