Idle Problems
Old Nov 26, 2001 | 04:54 PM
86iroctpi's Avatar
Car: 86 IROC
Idle Problems
My engine idles rough all of the time. It also doesn't have any power util about 2200 rpm. I tried cleaning the throttle body, but that didn't seem to help any. When I disconnect the small vacume line from the bottom of the tb, it idles fine, but at a higher rpm. Any suggustions?
86 iroc, tpi, auto, compucam, headers, pace-setter cat-back, stageII chip, afpr, air foil, filters, maf screens removed, gutted air cleaner box, 160* stat.
Old Nov 26, 2001 | 07:58 PM
Desert86Roc's Avatar
Are you showing a check engine light? If so, check to see what codes are being set and we can help out more.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] www.MetzlerRacing.com
Best ET @ 1250 ft[*] 15.352 @ 91.215 mph (uncorrected)
Old Nov 26, 2001 | 10:09 PM
86iroctpi's Avatar
Car: 86 IROC
No trouble codes at all. I tried adjusting the timing and tps and that didn't help either.
Old Nov 27, 2001 | 10:15 AM
86iroctpi's Avatar
Car: 86 IROC
Help Please!!! This is driving me nuts!!
Old Nov 27, 2001 | 11:23 AM
nblanchard's Avatar
This is a shot in the dark... but I believe the bottom vaccuum hose goes to the Charcoal Canister. If so, maybe your canister is clogged up? If its not the line going to the canister... where ever that vaccuum line is going, maybe there is a problem with that vaccuum controlled device.
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Best ET 14.559 @ 95.25MPH
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
