Anyone doing LT1 conversion?
Old Nov 18, 2001 | 08:40 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
My conversion is moving along slowly. It's been a lot more work than it looks like. I now have all the mods done to the intake and have trial fit the distributor. I have also made a new throttle bracket out of stainless. And a friend of a friend says he'll get me the fuel lines. Hopefully I'll be tuning before it snows.
Bob '89 Ram Air Formula 350
And until that time when death won't wait, let each man rage against his fate. (O'neill)
My car's homepage
Reader's Ride
Old Nov 18, 2001 | 10:25 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Very, very good. Sounds like your coming along great. Let me know if you need any advice.
Anyone else trying a LT1 intake swap?
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
Old Nov 18, 2001 | 11:11 AM
RCR's Avatar
RCR
Thanx John. You've answered a few ?s for me already.
thnx again...
Old Nov 18, 2001 | 12:22 PM
Bad 91z's Avatar
Im doing it and Im gonna need all the help I can get! As long as I can find someone to drill the distributor hole I should be okay. Anyone know who could do that for me?
Marty
Old Nov 18, 2001 | 02:49 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
<font face="Verdana, Arial" size="2">Originally posted by RCR:
</font>
Not many, because everybody told John it couldn't be done w/o an exuberant amount of money/resources, and John showed them all up by doing it in his home garage w/ parts from DAP and PepBoys. I think "they" are still in shock/denial.
I whish you the best of luck, and I'm sure John can walk you through any/all problems you may run into.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Nov 18, 2001 | 02:51 PM
age's Avatar
age
Car: 1992 Z28 1LE
just curious, but how much does the whole conversion cost? manifold, thermostat housing, fuel lines, etc..?
Old Nov 18, 2001 | 03:49 PM
RCR's Avatar
RCR
I'm keeping track of costs and will have it posted when done. I think I've spent about $200 so far. That's a net cost of $50
Old Nov 18, 2001 | 05:41 PM
Engine: 4.0L
I sold my old TPI (base, runners and pleunum) for $300 at e-bay. That offset the cost of the swap by over half.
Old Nov 18, 2001 | 11:55 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
I plan on doing the LT4 intake swap w/ Vortec style Fast Burn heads. Hopefully the ports on the intake and heads will line up with little or no porting. I'll let everyone know how it goes. I'll be doing it along with my new motor hopefully by Christmas time.
1991 Z28 - 350 TPI, T56, McLeod street clutch, LT4 pressure plate, Pro 5.0 shifter, ported plenum & runners, AFPR, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Old Nov 19, 2001 | 12:53 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
As soon as the finances straighten themselves out. I have the LT1 intake just taking up space in the garage. Plus I wanna make sure I have all the bugs worked out of the 89 RS convt ZZ4TPI before I radically change the equation.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Nov 20, 2001 | 10:28 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Those who are doing the swap... how are you tackling the computer issue? Will you be burning your own proms so you can keep the stock system?
Old Nov 22, 2001 | 08:16 AM
RCR's Avatar
RCR
Omega: It's easy for me, I already have Accel's DFI. It's just a slight program change on the laptop.
Old Nov 23, 2001 | 08:51 AM
zboss86's Avatar
I'm going to attempt this swap this winter while I have my motor out refreshing it.
Figure I'll port the hell out of her to fit the flow for the 406 and G2 heads.
I also going to have a speed-pro to make the tuning alittle easier.
I got a buddy running 6.82 with dragradials through a full 1/8th. He's got the same combo I got except he's got a miniram. I'm going to see how close I can get to that.
It should be interesting.
Old Nov 25, 2001 | 09:59 PM
cfabe's Avatar
I've got the LT1 intake sitting in my garage for the moment. Going to start the conversion in january when i'm out of school. I'm also going to try running it with the megasquirt DFI computer so it'll be interesting to see how that works too.
Old Nov 26, 2001 | 05:36 AM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by Omega:
Those who are doing the swap... how are you tackling the computer issue? Will you be burning your own proms so you can keep the stock system?</font>
I recommend keeping the stock computer and getting a prom burned. After all this was supposed to be a cheap swap!
86 Camaro Sport
LT1 Induction
My Camaro Project
Old Nov 27, 2001 | 09:24 AM
Omega's Avatar
Engine: LS1 / LS3
Cheap swap? The actual intake yes, but everyone that is doing it has DFI What in the world is a megasquirt?
Now i have a really REALLY good reason to get the prom burning equipment
Would this intake be too much for a 305?
[This message has been edited by Omega (edited November 27, 2001).]
Old Nov 27, 2001 | 12:30 PM
RCR's Avatar
RCR
Megasquirt: http://www.bgsoflex.com/megasquirt.html
It's definitely budget in the sense that if this were a Miniram, you would still need to do a chip/program. All the "extras" are still needed either way. So far, what's cost the most are the extras. Hoses, clamps, wiring, etc.
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
