350 Injectors on a 305
Old Jun 20, 2004 | 06:02 AM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
i can get my hands on a set of 350 injectors for my TBI. i have no mods other than my Open Element and exhaust. what will putting the 350 injectors on do to the car?
Old Jun 20, 2004 | 12:31 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
you wont gain much if anything, unless you have specific need to have larger injectors, like newer/better heads, larger camshaft, better intake, headers & to top it off chip tuning. these all equate to more power but if you dont get rid of the stock heads, intake and camshaft you never see the full potential of the 305.
Old Jun 20, 2004 | 12:50 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
If you use those injectors right now you will lose power, EAT gas, have horrendous throttle repsonse, kill your cat, and have an all out crappy running car. Save them for when you can burn chips and need them. You don't need to change injectors until you have serious heads and cam.
Old Jun 20, 2004 | 04:56 PM
92MaroRS's Avatar
ok. thanks for the input. anything else i can do fairly cheap that will give me a noticable gain in power. i will not be putting new heads or cam in this motor as i will be build up a Carb'd 350. but id like to get the car down to a 15.7-15.8 fairly cheap. if thats possible.
Old Jun 20, 2004 | 07:21 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You best bet is an open element, full exhaust, and ultimate TBI mods. Anything else to gain power will require chaning the heads and cam. However, suspension mods are worth their weight in gold. You can see low 15's and possibly mid 14's with just those mods coupled with the right suspension parts.
Old Jun 20, 2004 | 07:26 PM
92MaroRS's Avatar
already have open element. and a new muffler but didnt do anything before the axle. im hoping with the bumped timing and some different tires i can get into the 15s. just half throttle now will break the tires loose. before it wouldnt even do it at WOT with the timing where it was at.
Old Jun 20, 2004 | 07:31 PM
92MaroRS's Avatar
i also have 3.23 gears and POSI. anything i can do to the suspension to get me better times that would cost me less than 20 or 30 bux?
Old Jun 20, 2004 | 07:54 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Boxing your stock pieces or getting a few new bushings can be done for under 30 bucks. You are not going to get much for that. However, you may be able to get some used tubular pieces for that price. LCA's go for 99 brand new.
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
st.evel07
Aug 13, 2015 06:15 PM
