The "L03" Camaro runs!!! "sounds inside"
Old Jul 5, 2004 | 10:27 PM
NEEDforSPEED's Avatar
well i got it to run, you can hear it "HERE" i think its running to rich? or lean? i dunno but it sounds like its running tight ... till you give it a little gas, then pop ... ever time you let off it even if you let off slow ... we ran it a few times before i decided to make a video clip witch i just made a sound clip out of ... every things temporary in place i have not torque down anything to specs yet ... does any one know the specs for headers?
well at lest it has a nice idel
Old Jul 5, 2004 | 10:31 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I coudn't get your link to work. The only way to tell if you are rich or lean is to look at a series of data logs. You cannot go by sound or smell alone. The torque specs for hedders is tight.
EDIT: If your cat is not hooked up some popping can be heard.
Old Jul 5, 2004 | 10:34 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Sounds like you may need to check your timing.
Old Jul 5, 2004 | 10:52 PM
lol i just built a cable for logging in data...
https://www.thirdgen.org/techbb2/sho...hreadid=248159
but as you can see
so im kinda stuck.. i was hopeing to get some 02 read outs to see what A/F i was runing... i dont know if the 02 will get hot enof now with headers.... to get good reads...
Old Jul 5, 2004 | 10:56 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
but as you can see
It will be in a properly heated environment with shorties. However, our 02's are not very accurate if you are way off of stochiometric.
So what all did you do? Hedders only? Did you fix the link?
Old Jul 5, 2004 | 11:16 PM
it should work, if not i can send it to you in AIM?
Old Jul 5, 2004 | 11:41 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The link finally worked for some odd reason. It sounds typical of open hedders.
Old Jul 7, 2004 | 10:57 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
sounds better then it did!!! Cant wait to see what kinda power shes got now!!!
Jason
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 8, 2015 12:07 PM
Sherpajames
Aug 7, 2015 06:56 PM
