Wot Tps %
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
there is a setting in the 8746 for %throttle to enable PE. i would assume there is one in the 747 also.
BTW, i get about 102% when i go WOT. the PE Enable % is set to 50 in my chip. HTH
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Reason I ask is that I have a bored out TB.
After looking closely, the blades weren't traveling to full vertical at WOT. At this point, I was only getting 88% TPS.
I have filed the pad that stops the throttle movement. I now get true vertical on the blades, but still only get 92%
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Wot Tps %
Originally posted by va454ss
What tps % are you guys getting at WOT?
Is there a min % that the ECM recognizes as WOT, or is strictly by MAP?
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Car: An Ol Buick
Engine: Vsick
The only thing the ecm uses the TPS for at WOT is generate the PE AFR. If you see your commanded AFR matching the PE AFR your there. But, less then veritcal will deflect the fuel with a bias to which ever way the blades are pointing, so you want them to open fully.
Pac J
May 17, 2020 10:44 AM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
