Code 42 after MSD blaster coil???
Old Aug 5, 2004 | 01:26 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
OK I keep getting a code 42 ever since I installed the MSD blaster coil. When I first installed it the engine would start up then die emidiately. Tracked it to the MSD Coil wires not being tight enough to the coil so I zip tied the wire bundle to the coil and everything was fine. This code didn't come up untill a couple days after all of that. Any suggestions
Old Aug 5, 2004 | 11:44 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
How are the connectors themselves? When you say coil wires, I assume you are talking stock wires. Or are you running an MSD 6 w/ msd harness? If the clips are brocken on the connectors, then new connectors is the best way to go, or the zip ties if they do not bother you. Try cleaning them as well
Old Aug 5, 2004 | 11:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I think if he would relocate the wires elsewhere his problem would go away. They are getting interference from the coil and that is giving him the code 42.
Old Aug 6, 2004 | 12:42 AM
iggy1991's Avatar
Its all just the stock stuff except the MSD blaster coil. Granted the cap and rotor are Accel and the 8.8mm Accel plug wires. I'll clean everything with electrical cleaner in the morning and see what happens.
Old Aug 6, 2004 | 02:09 PM
iggy1991's Avatar
Well I cleaned all the connections and disconnected the ground at the battery to clear the codes. Still the code popped up almost emmidiately...now what? I hate having electrical problems cause they could be anywhere.
Old Aug 6, 2004 | 03:42 PM
loudpedal's Avatar
Car: DAF
Engine: 3 cyl 2 cycle
Transmission: variable speed
coil.........
a-b-a
unplug your trik coil and plug in the stock coil....see if things return to normal.
Old Aug 6, 2004 | 09:54 PM
iggy1991's Avatar
I tried that but I just forgot to mention it. Nothing seems to be affected by the code but its a PITA with the light on all the time.
Old Aug 6, 2004 | 10:08 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try disconnecting the positive cable from the battery, just disconnecting the negative cable isn't going to clear the codes.
Old Aug 8, 2004 | 01:07 AM
iggy1991's Avatar
Ok I figured it out....I guess I forgot to reconnect the tan wire for the distributor when I was setting the timing.
Hotrodboba400
Dec 10, 2019 07:07 PM
BumpaD82
Feb 26, 2016 02:57 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Jlanz55
Sep 6, 2015 03:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
