350tbi head??
Old Aug 12, 2004 | 09:10 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
350tbi head??
Ok i plan on swapping my 305tbi with a 350tbi sometime in the next couple of months and i've been searching the threads to find out exactly what to do. i've also been looking at other peoples set ups to find out what is the best. now for my question, i see a lot of people say they are going to use 305tpi heads but i havent seen anyone talk about the 350tpi heads. i have a chance to pick up some 350tpi heads but i dont wanna buy them and then find out that i should have went with the 305tpi heads. Any help would be great, Thanks
Old Aug 12, 2004 | 09:19 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
If you're going with a 350 it'd be better to use the 350 tpi heads or at least just as good. If you're sticking with a 305 it'd be better to use the 305 tpi heads.
Old Aug 12, 2004 | 09:21 PM
Car: 94 25th TA
Engine: 355LT1
Thats what i figured but then why would you put 305 heads on a 350? would that restrain it from making any real power?
Old Aug 12, 2004 | 09:39 PM
BronYrAur's Avatar
Engine: 305 TBI
Well the 305 and 350 tpi heads flow very similarly but the 305's have 58 cc chambers and the 350's have 64cc chambers. The 305 heads will boost compression and may not flow much less. Both sets of heads also respond very well to porting. Port a lot out of either of them and boost the compression a little you'd have a nice motor.
Old Aug 12, 2004 | 10:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
As Bron said there isn't much difference between the Iron TPI heads besides valve size and chamber size. I would also look at the vortec heads. They are an even better choice.
Old Aug 16, 2004 | 05:19 PM
Car: 94 25th TA
Engine: 355LT1
what would be some good choices on the vortec heads? i could get some off a late 90's truck, would those be a good choice or no?
Old Aug 16, 2004 | 06:21 PM
Car: 94 25th TA
Engine: 355LT1
Also if i go with vortec heads would i need a different intake?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
