L05 TBI Question
Old Aug 21, 2004 | 09:47 PM
cejohns's Avatar
Car: 90 formula
Engine: 305 TBI
L05 TBI Question
Where can i get a new or refurbished TBI for the L05.. I'm replacing the 305 with a recon L05 in my Firebired, or could i use the same TBI from the 305?
Old Aug 22, 2004 | 02:34 AM
adambros's Avatar
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
you can reuse it. the TBI is no different.
Old Aug 22, 2004 | 02:36 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Correct. Both share the common 1 11/16" bore. Only difference is the injectors (the 350 running the larger injectors, obviously).
Old Aug 22, 2004 | 08:54 AM
cejohns's Avatar
Car: 90 formula
Engine: 305 TBI
I can't remember the name of the place who takes your old TBI and modifies it. Does anyone know who this is?
Old Aug 22, 2004 | 10:14 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Off the top of my head, Turbo City is the name that comes to mind. However, I would think that for the price you pay there, the DIY guide is something to look at.
Old Aug 22, 2004 | 12:06 PM
cejohns's Avatar
Car: 90 formula
Engine: 305 TBI
Thanks..
Old Aug 22, 2004 | 12:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Is the 454 TB out of the question? That has a 2" bore...
Old Aug 23, 2004 | 09:42 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
Re: L05 TBI Question
I hope that you plan on changing those heads and cam from the L05.
Old Aug 23, 2004 | 12:43 PM
cejohns's Avatar
Car: 90 formula
Engine: 305 TBI
yes i do.. here is a link to them...http://www.paceparts.com/index.asp?P...OD&ProdID=8635
Old Aug 23, 2004 | 01:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
But what cam?
Old Aug 23, 2004 | 01:20 PM
cejohns's Avatar
Car: 90 formula
Engine: 305 TBI
this is one of the responses that i got about what cam to use, what do you think? I'd consider using the factory roller cam out of a 350 RamJet crate motor.
It's got short duration and high lift. It's EFI friendly.
Make lots of power and torque for a daily driver.
A good match for the vortec head upgrade. Especialy if you have a low rear gear like 2.73's.
It will fit without cylinder head machining.
Camshaft: 14097395 Roller Tappet Design, Lift .431/.451”, Duration @ .050, .196/.207
You may be able to buy this cam from some of the "performance" GM dealers that sell upgraded crate motors an sell off the stock parts cheap.
Pace chevrolet, Sallee chevrolet etc .
Old Aug 23, 2004 | 04:37 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Sounds like an Fbird'88 recommendation to me.
It is a small cam. Small enough to fit under the factory Vortec setup. Small enough to be EFI friendly.
It may or may not be the wisest choice. That all depends on what you want to get out of the engine. If you are looking for a cam that is pretty much a drop in and go and works with lower gears, then it looks like a decent choice to me. Another cam that has small duration and good lift is the LT1 cam from the F-bodies.
dur. @ .050": 203/210
Lift with 1.5 rockers: .447/.450
LSA: 117
It's pretty much up to you and how much tuning you want to do (if any at all) and what you want out of th engine.
MustangBeater20
Oct 29, 2022 09:20 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
