where the hell is the schrader valve?!?
Car: 96 s-10, and 89 camaro RS
Engine: 305 TBI with alot of mods
Transmission: 700R4 B&M shift kit
Does my car even have one? My car is a 1989 camaro RS L03. I want to run nitrous but i have to tap into the scrader valve for fuel on the wet side of the kit. And I really dont see one. If there isnt one can i incorperate one in to one of the fuel lines?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
No, there isnt any sort of valve to test the fuel pressure. Youll have to put a gauge in somewhere along the feed line.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
yup, no shrader valve, you have to tap into a softline somewhere.
a soft line?? I was thinking of taking a schrader valve off of my S-10s line and having a welding shop weld it into place. Would that work?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you find a shop willing to weld on your fuel line, i suggest you never go there again.. lol.
with nitrous systems, i always reccomend a stand alone system, but other then that, just cut the fuel line somewhere and put a Tee in.
if you do it in the metal line, you can flare it and use all hard line...
if you do it in the soft flex line, you can just use nipples and hose clamps.
dimented24x7
Sep 6, 2015 03:51 PM
