Quest for the 13.99 pass will this get me there??
Old Sep 2, 2004 | 09:32 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
ok guys im going for it a N/A LO3 running 13s
my current ET and mods are in the sign
as of right now my car is completly tore apart heres what i have so far
1.)Edlebrock TBI Cam
2.)Edlebrock TBI Intake Manifold
3.)MSD Distributer
4.) 1.6 Rockers (dont have those yet still shopping)
as far as my rear goes i went with this
1.) 4.11 Richmond gears
2.) Auburn Posi
3.) Moser 28 Spline Axles
best ET is a 14.56@93mph can this set up get me the 13.99 pass???
Old Sep 2, 2004 | 09:43 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What are the specs on that cam? I hope they are not the typical generic lame grinds that Edelbrock is famous for. I would have that intake bored to 2" since you have the Holley 670. After that, chip work and more chip work. I will go out on a limb here and say that you will run slower than your previous best on your first couple of burns. It will take some time and patience but once you get your tune dialed in you could see those times. The gears may be a bit steep and I doubt they match the cam or the powerband that your new combo will produce.
Old Sep 2, 2004 | 11:20 PM
Teal91rs's Avatar
Car: 1991 Camaro *RIP* 1984 MonteCarloSS 1972 Nova
Engine: 355 cid 383 cid
Transmission: TH350 TH350
Try a costom ground cam lots of tuneing open headers skinnes and a pair of e/t streets and i think it wouldnt be that far off
Old Sep 2, 2004 | 11:57 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Quest for the 13.99 pass will this get me there??
3.)MSD Distributer
2.) Auburn Posi
Id go with a different cam. The edelbrock cam is probably weak and not much better then stock. Also, does edelbrock make a roller for tbi? I couldnt find the specs. As far as the cam, something with around 210-212 deg of duration at the intake lobe would be nice*. Depending on the cam you may want to also get better valve springs and good steel rockers. Better set of heads is also in order. Jsut about anything out there is better then the stock heads. A set of tpi heads would be a good place to start.
*Tuning will be required.
Old Sep 3, 2004 | 03:52 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
That setup is weak.
You need a bigger cam and heads.
Old Sep 3, 2004 | 06:16 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Just out of curiosity, why are you still modding teh car if its for sale? Youll need that money for the tpi car in your sig. Youll almost be at the same place with that as you where with the stock tbi.
Old Sep 3, 2004 | 10:18 PM
25THRSS's Avatar
Are you trying to do this on the stock heads? If so I would check out the flow numbers on the stock L03 heads in the first vortec 305 issue of CHP. Get a cam that matches the flow numbers with some good duration. I wouldn't waste your money on a distributor either.
Old Sep 4, 2004 | 10:48 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
OK guys, here's his Edelbrock's TBI cam specs:
194/214
.398/.442
Lobe Sep = 112*
Intake Centerline = 107*
Now that's some long duration (even more than mine), but I think that the intake lift is too small, especially compared to the exhuast lift. I don't think I've ever seen a cam with that much of a difference between the two.
For what it's worth, I had one of their "Performer" cams in my 460, and it was a complete waste of money.
That was my first real project, so I pawn it off as lack of knowledge.
Old Sep 4, 2004 | 03:39 PM
Car: 88 Camaro SC
Engine: SFI'd 350
In my honest opinion, that grind is a joke. Is it even a roller cam? That looks like their flat tappet profiles.
Old Sep 4, 2004 | 05:36 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
no the cam is a roller cam and i still can use the roller lifters
as far as the car being for sale the answer is no i just havent had a chance to delete it from my sign
i got rid of that iroc because it was just too banged up to deal with.one headache is enough lol
Old Sep 5, 2004 | 01:07 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
You need a way bigger cam, and maybe some DIY head porting??
Old Sep 5, 2004 | 01:25 AM
Car: 88 Camaro SC
Engine: SFI'd 350
lol, I can definatly relate to the headache part.
Like everyone else has said, you need a better cam. If your going to be going through all the effort to swap cams you should definatly go for something good. The tbi cam is barely even a step above the stock one and will produce little gains in performance. Something like the compcams XR269HR with 112 LSA or maybe a ZZ4 cam. Not as much duration but paired up with a good set of heads it could make some decent power.
Call the cam manufacturers. Im sure they could steer you toward some of their products that would best suit your needs.
Old Sep 7, 2004 | 04:00 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
The cam that edelbrock recommends in their power package isn't a roller cam as far as I remember. I definitely agree go bigger.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
racereese
Oct 3, 2015 03:46 PM
