code 54
Old Oct 10, 2004 | 01:50 PM
jase's Avatar
code 54
The other day i had a quarter of a tank and I put 2 gallons in so I could make it to and back before I got paid.I was on flat ground when I was almost to work and my car made a small noise and a jerk and was dying.I had my cruise on and I put my foot in it cause it was dying and it would't help.I coasted up the ramp and pulled over and started the engine.After about 3-4 seconds it started up and has not given anymore problems since.I tried to if there where any codes,but none.If a fuel pump was trying to go out,would't a code 54 show up?I am ruling out the int.moduler since it has been 3 days since this happen because it has't happen anymore.Maybe water was in the tank?
Old Oct 10, 2004 | 05:51 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Sounds like it ran out of gas. Even if the gauge said it still had some gas in the tank it was probably wrong. Keep about 5 or more gallons in it for a week or so and see if the problem comes back. Its real easy for the gas to slosh around and expose the pickup on the pump. Once that happens, the fuel pressure drops to zero and it jerks or dies. Ive done it lots of times. Its how I know when its really time to get gas since my gauge is beat.
Old Oct 10, 2004 | 05:55 PM
Car: 88 Camaro SC
Engine: SFI'd 350
As for the code 54, that wont set unless there is zero voltage being delivered to the pump. Diagnostic for the fuel pump relay, really.
Old Oct 10, 2004 | 07:46 PM
jase's Avatar
Thanks.Iwill try that.But could water in the tank do that too,or maybe some trash.The filter was changed last Nov.
Old Oct 11, 2004 | 01:26 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Possibly. Theres a strainer on the pump pickup. Although if it was clogged its unlikely the problem would have gone away.
Old Oct 11, 2004 | 04:11 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Lol, I'm the same with Dimented, only my guage does work IIRC, the fuel pick-up is in the back left corner of the tank, so if you are making a right-hand turn and/or brakeing that can cause the pickup to just suck air. (ever notice your gas needle moving when you brake/accelerate?) I have that 'lack of fuel' problem all the time, it's nothing to worry about...
Bruce (90RS305)
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
