Gas Miliage downt the drain
Old Oct 21, 2004 | 03:29 AM
CrashRS91's Avatar
I have a 91 RS 305 with around 170,000 miles on it its developed a slight lifter knock when its cold it idles constant but a little rough. On my last tank of gas for some reason I got around 96 miles! Now if I do the math on that with around 15 gallons of usable fuel that’s less than 7 mpg! This is outrageous I didn’t drive it into the ground just lightly around town. I usually get around 200+ miles to a tank. I am going to change the o2 censor tomorrow but it was new just a couple months or so ago. I could really use some advice here I am just a poor college student and I cant afford this 7mpg stuff!
Old Oct 21, 2004 | 08:19 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Do a good tune up.
02 sensor
Cap/rotor
plugs/wires
Those 5 things will go a LONG way in making a good running motor.
are you sure you have lifter knock??? and not a bearing, or exaust leak? What kind of oil are you running, and how long has it been since the last oil change?
Old Oct 21, 2004 | 02:15 PM
CrashRS91's Avatar
I change it at least every 3000 miles and I usualy mix it up between some synthetic and normal 5w-40 but the know has been around for 20,000 miles or so. But I never really investigated what is was I just assumed it was a lifter.
Old Oct 22, 2004 | 12:31 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Check for leaks in the lines....
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
85cmroz28
Oct 4, 2015 09:44 PM
kx3g
Sep 28, 2015 08:14 AM
ericjon262
Sep 11, 2015 06:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
