Air/Fuel gauge says its running rich
Old Oct 21, 2004 | 10:01 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I just installed a air fuel gauge in my camaro, The tranny is out on it right now but i can still drive it i first gear. Anyhow, i let the car warm up completely and drove it around the block, when i got back to the driveway, and let it idle the gauge was one green bar into the rich. How do i keep it from running rich?
Old Oct 21, 2004 | 11:27 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Sounds like it may have gone into open loop. Dont know if the later ecms do that but mine does. In closed loop the AFR will bounce around like a ping-pong ball. Itll probably be a tad rich in open loop. Nothing wrong there.
Old Oct 22, 2004 | 09:58 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ok, well next week im getting my new tranny installed and ill have it back on the road and ill be able to moniter it better,
Old Oct 22, 2004 | 12:06 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
As Minented said it should bounce back and forth when in closed loop. The AF gage is more of eye candy than anything usefull. Even at WOT when it goves you a steady reading the output of the gauge is a crap shoot at best. Our single wire 02's are horrendsouly inaccurate when you are 1 or 2 percent within stiochiometric.
MustangBeater20
Oct 29, 2022 09:20 PM
rocn7roc
Sep 21, 2021 02:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
squiggy2
Aug 9, 2015 09:30 PM
