Q about 454 TBs
Old Nov 4, 2004 | 11:26 PM
elkabong's Avatar
Car: 84 Vette
Engine: 383 XFire
Q about 454 TBs
I have a 84 Vette that is currently undergoing a head and cam swap. I also have the infamous XRam (no basing please I have limited options). I am contemplating slapping a 454 TB on top of the Weiand manifold that comes with the XRam but I can not find any info on the pinouts of a 454 IAC or TPS. Would anyone happen to know a good source for info on the pinouts?
Thanks.
* I guess I should have read closer. I did find the pinouts for the IAC but nothing on the TPS.
Ton's of info here.
Old Nov 5, 2004 | 12:29 PM
Ronny's Avatar
i have an 454 TB adapter plate new not used with gasket. i think 1/2 inch (howell eng.). also a TB spacer from TC also not used? i was goona return to them but?
Old Nov 10, 2004 | 07:44 PM
elkabong's Avatar
Car: 84 Vette
Engine: 383 XFire
Ron - Sorry for the delayed return been kind of busy. You know my email address...... Drop me a note and we can go from there.
Old Nov 11, 2004 | 09:39 AM
Ronny's Avatar
sorry returned yesterday. point of interest is that the howell is only 1/2 thick. thinnest i could find. it did offset the TB about 3/16 inch. again fuel distribution related? or is offset for linkage?
Old Nov 11, 2004 | 11:49 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
That offsets a real pain. Ideally you want the tbi to be centered so there arnt any problems with the linkages. I can tell you first hand that the fastest way to ruin a trans is to screw up the TV geometry.
Old Nov 11, 2004 | 12:29 PM
90_WS6_Formula's Avatar
Car: 91 Z28
you don't screw up the geometry if you have a mounting point you can move with the TBI That's how I got around it.
Old Nov 11, 2004 | 01:37 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Thats fine, but not everyone may know that you cant change it by moving the tbi but keeping the stock mount. Like you said, as long as teh relationship doesnt change, the tbi can be wherever you want it.
Old Nov 11, 2004 | 06:39 PM
Car: 91 Z28
another issue with moving the TB further front would be that them cables get rather tight
Old Nov 12, 2004 | 09:20 AM
Ronny's Avatar
the holley projection TBI manifold was a straight bolt on with GM 454 TB. needed to mod the holley throttle bracket a bit but the linkage was perfect.
MustangBeater20
Oct 29, 2022 09:20 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
