more intake manifold questions cause my last one got shutdown
Old Nov 12, 2004 | 10:37 PM
90Formula305's Avatar
Car: 1990 Pontiac Firebird Formula
Transmission: 700 R4
Axle/Gears: peg leg
ok, which one would any of you recommend out of edelbrock, holley, or gm performance?
Old Nov 12, 2004 | 10:40 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: more intake manifold questions cause my last one got shutdown
edelbrock then holley
Old Nov 13, 2004 | 08:55 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I only locked the last one because this question has been asked a million times. With a few minutes of your time you can search past posts that include everyones opinions on these intakes. There wre tons and tons of disscussions out there. We don't need to waste bandwidth by adding one more that will be a duplicate of all the others. I am really confident you will find your answer. If we just tell you what is the best one you won't learn anything and the intake will most likely not match your combo. There is no "best one", because they all work for different types of set-ups. Some of the lower performing intakes are a better choice for people. A few searches will tell you why. There are a few links in the stickies up top that cover intakes very well. Please read them. Good luck and happy modding.
ASE doc
Alternative Port EFI Intakes
Jan 12, 2020 11:35 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
