A.i.r.?
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
First off, if you didn't know about it yet there is a
button on the top right corner of every screen that you can use to find older threads on topics you might have questions on. Perdy much every thread ever made on TGO has been archived, so there is a WEALTH of knowledge to be found here! On that note, as far as your A.I.R. system is concerned, if your car is still completely stock then you are guaranteed to have it. If you wanna know what it looks like, the part circled in red (below) is the sorta "control unit" for the system. That unit has tubes running from it to both your smog pump and these niftly little tubes all hooked to your headers. HTH!
Bruce (90RS305)
button on the top right corner of every screen that you can use to find older threads on topics you might have questions on. Perdy much every thread ever made on TGO has been archived, so there is a WEALTH of knowledge to be found here! On that note, as far as your A.I.R. system is concerned, if your car is still completely stock then you are guaranteed to have it. If you wanna know what it looks like, the part circled in red (below) is the sorta "control unit" for the system. That unit has tubes running from it to both your smog pump and these niftly little tubes all hooked to your headers. HTH!Bruce (90RS305)
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your motor came with it from the factory. It should be there unless a previsou owner removed it. Check the "new to TBI" stikcy up top for more threads dealing on the AIR system. These threads will cover identification as well as removal tips.
