The proof is in the puddin'! (track times)
Old Nov 28, 2004 | 03:08 AM
azvolfan's Avatar
Car: currently thirdgenless!!!
Well I finally got the camaro to the track. Picked up another .6 seconds in the 1/4 mile. Here are the results
Reaction time.............................742
T1 (60' time)............................2.339
T2............................................6.610
T3...........................................10.107 @ 69.282 mph
T4...........................................13.045
1/4 mile..................................15.672 @ 89.06 mph
My previous best was a 16.2.
So the gears, intake and chip work got me another .6 seconds. But I still think there is more in there.
If you plug the numbers into the horsepower estimater on the Speedworld website it says I making 224 at the crank and 190 at the rear wheels.
I was hoping for a little better but I am happy with the results. For now.
Old Nov 28, 2004 | 03:13 AM
azvolfan's Avatar
So anyway, James was out there with me and I asked him to take the car for a run down the track to see if he could do any better. Here are his results:
Reaction.........................710
T1................................2.343
T2................................6.512
T3................................9.986 @ 69.275
T4..............................12.907
1/4 mile......................15.523 @ 87.474
James was a little quicker down the track than me. Guess I need to learn to drive better.
Anyway it was a good time.
Old Nov 28, 2004 | 05:54 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Work on your 60 ft times.
Those calculators are set up for a vehicle with optimum traction and gearing.
Get your 60 ft down to around 2.0 (preferrably less) and you may break into the 14's.
Old Nov 28, 2004 | 09:44 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Your progress is great but there is still more in her. Are you still using the stock fuel system?
Old Nov 28, 2004 | 10:17 AM
JPrevost's Avatar
Car: 91 Red Sled
Test out the fuel pressure at the track. Do a baseline run, then increase it by 2psi, another run, etc. This is how you have to go about it until you have a real chip.
Old Nov 28, 2004 | 10:42 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Do these track times reflect the change from stock air cleaner assembly to dual snorkle?
L03 with the Rochester TB unit still? Where did you get the dual snorkle and how much did you pay?
Encouraging and Thanks for sharing!
Old Nov 28, 2004 | 01:19 PM
azvolfan's Avatar
I am still running the stock fuel system including the stocke pressure regualtor.
When I get the adjustable regulator back on, I will take it to the track and try some adjusting.
The time are with the dual snorkel and not the stock cleaner assembly. As far as where I got it, I got in on ebay and paid $150 for it including all the duct work. Then I sent it to a plating shop and had it plated in black chrome for another $260.
They are harder to come by but the are still out there.
As far as performance goes, there is little if any difference between a dual snorkel and an open element. I ran almost identical times with both. Granted it was on different days, but the times were similar. So if you are having a hard time finding an dual snokel, your not loosing anything with an open element.
Old Nov 28, 2004 | 01:46 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its good to see that your making progress. I would think by the time all is said and done, you could be running mid to low 14's.
Old Nov 28, 2004 | 04:03 PM
JPrevost's Avatar
Car: 91 Red Sled
I've got an L69 dual snorkel air cleaner assembly. I got it for $50 5 years ago, it was in slightly rusty shape and had dings in it everywhere. I gutted the thermac stuff out of it, painted my air cleaner lid and got a K&N for it, never had the ducting hooked up, lol. The good old days of not knowing WHAT I was doing.
I tried fitting it up with my setup now and it won't fit no matter what I do. TBI sits too high, flatter base (front of air cleaner hits), and before that becomes a major problem the air snorkels are pointed directly into my Edelbrock 3-point STB . I'm holding onto it for a friend that's building up a mint condition 84 cutlass (was a v6) that he's building up with a 400sbc. I hope to get him to do the ULTRA sleeper with everything gutted but there . Black block, valve covers, intake, everything there but it runs mid to low 11's n/a, hehe.
Old Nov 29, 2004 | 03:41 PM
Cadillac's Avatar
Thanks Azvolfan.
I'll stick with the open element then.
Old Dec 4, 2004 | 04:43 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
and now.... faster.... but - We're gona get those 68matched in yer pod... then after xmas we'll check your fuel map out a bit.
Old Dec 4, 2004 | 04:50 PM
azvolfan's Avatar
I should put my chip on a chip reader and see what they did.
Old Dec 4, 2004 | 05:34 PM
JPrevost's Avatar
Car: 91 Red Sled
Old Dec 4, 2004 | 05:40 PM
snflupigus's Avatar
jan 3rd I'll have all my stuff down here in AZ
Old Dec 5, 2004 | 05:40 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
You're gonna be one popular dude Nic
Old Dec 6, 2004 | 02:27 PM
90_WS6_Formula's Avatar
Car: 91 Z28
you're our hero, nic
Old Dec 7, 2004 | 11:54 AM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
Azvolfan did you ever get your Dyno print out back to see what your real numbers are?
Old Dec 7, 2004 | 06:54 PM
azvolfan's Avatar
No I did not. To fix it they need to take the dyno computer down for 2 days. They said they are way too busy to do it right now.
I'll get it eventually.
Old Dec 7, 2004 | 10:38 PM
SchwarzCamaroRS's Avatar
hey nic, are those seats comin with it??? lol, yes, you will be very popular... i just got a better paying job too, so i might have to employ your services as a chip burner soon... maybe then ill be able to actually beat bruce... lol
Old Dec 8, 2004 | 07:46 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Re: The proof is in the puddin'! (track times)
And just think, after all that, your ALMOST in stock l98 territory! Only about a second to go... good job!
Old Dec 8, 2004 | 09:01 AM
NYC LSC's Avatar
Car: 1987 Lincoln Mark VII LSC
Engine: Novi'ed 304 H.O.
Axle/Gears: 4.10 Trac-Lok w/ Moser axles
15.6? That's some beast!!
Old Dec 8, 2004 | 10:36 AM
Matt86Z's Avatar
wow, think of all the stock LG4's you'll outrun in four miles.
NEXT?
Old Dec 8, 2004 | 01:24 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
I think he was happy about the improvement even though his car should be alot faster.
Old Dec 8, 2004 | 06:11 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
he should be thank full it ran that good
Old Dec 8, 2004 | 06:30 PM
azvolfan's Avatar
I'm very happy with the improvement. But your right, I think there is more in it.
Old Dec 8, 2004 | 06:48 PM
Guest
Guest
Posts: n/a
Damn, thats almost as fast as my moms stock 97 T-bird. :hail:
Old Dec 8, 2004 | 07:05 PM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
I didnt think it was possible to actually smell sarcasm...
Old Dec 8, 2004 | 07:06 PM
azvolfan's Avatar
Actually my mom has a 97 T-Bird also. A blue one. And it is much slower than my Camaro.
Old Dec 8, 2004 | 09:12 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Lets try to keep the sarcasm to a minimum...
Old Dec 8, 2004 | 11:11 PM
90RS305's Avatar
I second that. Bill's camaro is defnitly a beast. Unfortunatly, some people that own dynos don't realize that certain parts cause certain limitations. Just wait till' Febuary, that purple monster will be roaring down the road
Bruce (90RS305)
Old Dec 8, 2004 | 11:43 PM
Car: 91 Z28
let's line them up the next time I'm down that way
Old Dec 8, 2004 | 11:46 PM
90RS305's Avatar
You sure your 4 cylinder can handle it?
Old Dec 9, 2004 | 12:00 AM
Car: 91 Z28
oh how our mods like to sling dirt too
well... it's funny because TPIss is supposed to be SO much more superior than other GM induction systems and my "4 cyl is just as fast as Bill's TPI TA. ... go figure
Old Dec 9, 2004 | 12:17 AM
90RS305's Avatar
lol, you know I'm kiddin', and you have to admit when you heard about what the guy said you thought it was funny too! A friend of mine actually had a 5.0 thunderbird (H.O.) that, according to numbers, was quite a bit more powerful then my camaro. He came close a few times, but he never could beat me...
Old Dec 9, 2004 | 12:25 AM
Car: 91 Z28
that was actually in reference to the TPIss crew that flew in to flame on Bill's RS.
It was funny what the announcer said. He only said that because I didn't bother filling out the tech card and the he opened up his mouth and put his foot in when he was bragging about how his V8 Dakota would turn et's a bit slower than my 4 cyl
Old Dec 9, 2004 | 05:31 PM
90RS305's Avatar
Old Dec 9, 2004 | 07:59 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
He may be running a 15.6 now but with the right fuel and chip work I wouldn't be suprised if a whole second came off that time. The best motor in the world will run like poo if it is not fed and tuned correctly.
Old Dec 9, 2004 | 08:51 PM
azvolfan's Avatar
Precisely my thinking, Shifty. Let 'em laugh now but I'll be in the mid 14's in no time.
Old Dec 9, 2004 | 09:28 PM
90RS305's Avatar
(impression of that old 'shake&bake commercial)
"And I Helped!"
Old Dec 10, 2004 | 05:19 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Azvolfan, you have to do something with your 60 ft. Also what were the conditions of the run? You should be able to get faster than that, my taurus does that. :shrug:
Maybe take a step back and analyze a few things to better the time as well. Can you guys datalog well while running?
Old Dec 10, 2004 | 05:30 PM
Car: 88 Camaro SC
Engine: SFI'd 350
I almost wish I could stick my head through the computer screen and hear/feel it run. I suspect that its probably the fueling or the spark that are way off.
Old Dec 10, 2004 | 05:48 PM
  #42
Redbird's Avatar
Car: '87 Firebird
Engine: '89 Corvette L98, unstock
Axle/Gears: 3.23 posi
True. But won't poo still run like poo no matter what state of tune it's in?:shrug:
Old Dec 10, 2004 | 06:21 PM
  #43
NYC LSC's Avatar
Sir! Yes sir!
(Take a joke, junior. I was around these parts - under a different name - while you were still going through puberty)
Old Dec 10, 2004 | 06:46 PM
  #44
azvolfan's Avatar
Yeah, the 60' is not too great. That night was real cold and no one was getting much traction. That 2.4 on the last run was with a lot of wheel spin. But still, I have no suspension work and street tires. Drag radials and a little suspension work will help the 60' time. I just haven't gotten that far yet. Still working on the motor.
Old Dec 10, 2004 | 06:47 PM
  #45
azvolfan's Avatar
I thin for the most part dimented is right. I think it's in the fuel and spark. I may need to get better injectors and a better ignition.
Old Dec 10, 2004 | 07:07 PM
  #46
JPrevost's Avatar
Car: 91 Red Sled
You don't need better injectors, just more fuel pressure. You also need a real tune, none of this stock fuel pressure and injectors that go static at 4000rpm.
Old Dec 10, 2004 | 08:30 PM
  #47
Car: 88 Camaro SC
Engine: SFI'd 350
Sir! Yes sir!
Well, Im a little older then that . No offense taken, but we usually run a tight ship on this board.
Old Dec 10, 2004 | 08:31 PM
  #48
Car: 88 Camaro SC
Engine: SFI'd 350
As far as tune goes, its amazing how much of a difference it can make.
Old Dec 10, 2004 | 09:23 PM
  #49
azvolfan's Avatar
What exactly do you mean by static?
Old Dec 11, 2004 | 12:04 AM
  #50
Car: 88 Camaro SC
Engine: SFI'd 350
Theres only so much time an injector has to be open. If the ecm ends up spec. more time then whats actually available, the injectors will remain open the entire time.
