TBI Spacer
Old Dec 9, 2004 | 01:57 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
TBI Spacer
is it normal for a tbi spacer plate to cause bogging and loss of power if you don't have stock chip?
thanks,
Kyle
Old Dec 9, 2004 | 05:13 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Check for vacuum leaks around the spacer as well as full movement of the throttle spring.
Old Dec 9, 2004 | 06:59 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
I found the problem, only one injector was working, it blew a fuse due to a short, problem solved.
Thanks,
Kyle
Old Dec 12, 2005 | 07:06 PM
ACarp13's Avatar
Car: 1992 RS 25th Anniversary Convertible
Engine: 305 TBI
TBI Spacer
I'm a new member and have a basic question. Does any Company manufacture a spacer plate, appoximately 1" to 1.5". Eventually I'm installing a new motor; however, would like some emmidiate increase in hp. Thanks.
Old Dec 12, 2005 | 08:43 PM
TierAngst's Avatar
Car: 78 Caprice Coupe
Engine: 355
Transmission: 4L60
There are places that make them, try ebay look for xtremefi they sell spacers not sure the size. Turbocity.com has spacers, and so does cfm-tech.com
I haven't ever heard of anyone getting any significant gains from a spacer though. I'd do one of the other cheap or free mods before going with a TB spacer.
Old Dec 13, 2005 | 08:48 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Re: TBI Spacer
I would stay away from a 1" tall spacer. You will more than likey have hood clearance issues unless you run an aftermarket hood. You will also have throttle linkage issues that will take some serious tweaking to make the throttle actuate normally. Spacers are good as in you want as much plenum volume as possible. However, they are tough to work with since they are a pain to install and maintain a leak free TBI with proper throttle movement.
S10K20
Oct 7, 2015 06:45 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Glowsock
Sep 11, 2015 11:09 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
