help with engine mis
Old Dec 21, 2004 | 11:20 AM
streetracer516's Avatar
ive got a 89 formula with a 305tbi(toilet bowel injection) that just failed NY emissions. car ran fine about a month ago. now whenever i give it about half throttle at 2500rpm or above just about nothing happens it doesnt accelerate and doesnt run on all cylinders. the mechanic who did the emissions told me the car needed a tune up and a knock sensor. i did plugs wires cap rotor and the knock sensor and its still doing this. somebody please help because im stumped.
Old Dec 21, 2004 | 11:26 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Let's give the guys on the TBI forum a shot at this.
Old Dec 21, 2004 | 02:27 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Re: help with engine mis
That'll get you lots of help
Old Dec 21, 2004 | 02:35 PM
five7kid's Avatar
I guess I should have said something about that. See it a lot on the carb forum with "quadrabog", too.
Try to overlook and forgive, and get him back from the dark side, if you could.
Old Dec 21, 2004 | 03:28 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Check the spray pattern on your injectors. They should be a nice solid cone shape. How many miles are on it? Might want to consider rebuilding the TBI unit, the rebuild sets are like 30 bucks for all new gaskets and filters and everything.
Old Dec 21, 2004 | 04:25 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
When was the last time the fuel filter was changed?
Old Dec 21, 2004 | 05:06 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
should also check your fuel pressure and see what it reads when when the pump is primed but the engine is started.. its possible you fuel pump died as well.
Old Dec 21, 2004 | 05:44 PM
89Z's Avatar
89Z
Car: '89 IROC Z
Engine: TPI 305
Sounds to me like a clogged catalytic converter. Try removing the oxygen sensor and start it up for a very short time. Without the oxygen sensor installed, if the catalytic converter is clogged up, the exhaust gasses will have somwhere to escape and the car should run a little better. Obviously, it would be better to remove the catalytic converter to try it out, but just removing the oxygen sensor is a whole lot easier and quicker.
Old Dec 21, 2004 | 06:25 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I agree that it is a fuel problem. Check your feed line pressure. You pump may be dying and only suppling enough fuel to make your car run how you describe. Check the injectors as mentioned above for a steady cone shape flow. Even still you should check the feed line pressure because looks are decieving. 4psi will still make a cone shape but will not be nearly enough fuel for the car to run.
Old Dec 21, 2004 | 10:31 PM
thedogs's Avatar
Car: firebird '89
Engine: 305 tbi
Transmission: it works I'm happy
is your car throwing any codes?
how does the exhaust smell?
did you disconnect the battery to reset the computer? Silly I know.
when did this start happening?
have you tried giving the guy $100
Old Dec 22, 2004 | 10:07 PM
check engine light JUST started coming on and off. im going to scan it tomorrow. fuel filter has never been changed to my knowledge(recently bought the car). got about 120k miles. we'll see what happens with the scanner tomorrow and ill keep you guys posted.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
