48mm bore limit on stock TBI
Car: 1993 silverado 4x4
Engine: vortec 350, performer rpm intake, headers
Transmission: 4l60
is the limit because of the vaccum ports or wall thickness? i've got access to mills and lathes so custom throttle blades aren't a problem. is it possible to mill the bores length-wise in order to avoid the vaccum ports(if thats a problem)?
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
If you go any larger than 48mm you start cutting into the cavities behind the bore walls. Even at 48mm you have to plug the CCP ports or else you'll have 2 big slots in the bores.
Throttle plates aren't square. They're cut at an angle so making them would be alot harder than it's worth. You can buy a set cheap from Holley.
Transmission: 4l60
unless by cheap you mean $10 i think i'll be making my own. is there any way to remount the injectors to the intake or would i be better off just getting a wiring harness off a TPI camaro and go tuned port?
basically what brought this question up for me was this auction-http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7943259712&category=33558
Car: DAF
Engine: 3 cyl 2 cycle
Transmission: variable speed
48 mm on a 220 TB....not really
you asked the same ? on another board I believe.....
at the end of the day modifying a SB Rochester 220 will cost you way more in time and material than an off the shelf BB TB piece or the Holley aftermarket TB.
Transmission: 4l60
my dad owns a machine shop so there wouldn't be any cost besides my own time and no I haven't asked this question on any other board.
NinjaNife
Aug 23, 2015 11:49 AM
