Nitrous
Old Jan 22, 2005 | 10:28 PM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
Nitrous
Does Anyone Have Pictures of a carburated plate system which has been modified for use with TBI. Iwas wondering if I could use the NX "Gemini Twin" system. Thanks
Old Jan 22, 2005 | 10:36 PM
sunset92's Avatar
Car: sunset orange 92
Engine: 5.0
Transmission: t-5
i know ther is a kit made for tbi trucks. as far as the plate i would think you would need some way to get more fuel into the engine. since we don't have a vacuum assisted fpr. and some nitrous kits work off of those.
Old Jan 22, 2005 | 10:39 PM
I am going to put an adjustable fuel pressure regulator on. Anyways the nitrious system has it own fuel supply since it is a wet system.
Old Jan 23, 2005 | 12:05 AM
25THRSS's Avatar
You can use it as long as you have a carb intake manifold and an adapter plate. Just install the nitrous plate between the manifold and the adapter plate and change fuel jet's according to fuel pressure.
Old Jan 23, 2005 | 11:41 AM
TMoNeE's Avatar
Car: 87 Z28
or just get the kit thats for our cars,,, NOS and i think nitrous works makes em.
Old Jan 23, 2005 | 11:55 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I've had no problems, I'm running the NOS Super-Powershot system on mine. Reason I went this route, is that I got a carb system for Cheap...
here's a rundown.
Due to the height on the plate + adaptor, the bolts holley supplied with my adaptor were to short... Solution, I went to studs in the inkake, that were the correct lenght.
Plate installed.
Adaptor plate on.
Here is a shot, you can see where the spray bars site.
We had to do some 'modification' to the TB to get it to bolt in, along with micro switch, and the new studs. Nothing a grinder can't solve.
And finaly... A shot of where I mounted the bottle.
All in all, it goes on pretty easily, grinding on the TB to clearance for the mircro-switch was the biggest PIA.
Old Jan 23, 2005 | 09:31 PM
I am running a single plain intake with the exact same adapter as shown in the pictures. what jets are you running. Thanks.
Old Jan 24, 2005 | 12:58 AM
Dewey316's Avatar
Car: 1990 Camaro RS
According to holley, jetting is as follows.
47, 36 -- 100
52, 39 -- 125
65, 42 -- 140
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
