CAN i pass emissions
Car: 91firebird, 2000 camaro
Engine: 305 tbi,K&N, edelbrock intake & 3.8
Do you guys think i can pass emissions with open element air filter on the car because i think it will raise the hydrocarbs or should i switch back to the orginal set up just to be safe?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you should be fine, unless you have to pass a visual, and the inpector cares. If anything the open element, may lean you out a hair, if that happens your hc's will drop a hair, and NOx will go up a hair. I would test with it on, and see what happens.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I agree with Dewey. You should pass without any problems. A visual inspection may give you problems. If you are unsure just swap the stocker back on. It only takes about 2 minutes to do so.
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
I passed no problem with my open element on there. lol, I even had half the staff at the emmisions place under my hood when I went there asking me how much I liked it and complimenting me on how shiny it was
Bruce (90RS305)
Bruce (90RS305)
Alright then, They dont under the hood any how. if i dont pass ill just do it again with it the stock one. But i have the worst luck with emissions, when i frist got the car i to pay like $500 for a processer then i had to take again a few months later (cause the car hadnt been test in so long) and failed end up getting a new exhuast for like$250. Then while at the mufffler shop the fuel pmp decides to go out. Then changed the fuel pump and when we did that we accidently bent the neck, which made a small hole in it which cause me to fail emission once again. Took out the gas tank drained it and weld the hole. Put back to gether failed again because the place i took the car to that told us about the leak for got to put all of the air intake on, which cause the car not to get enough air an fuel mixture and gas was drippin out of the cat put it back together and the car finally passed. That was all a bunch of
That.....really sucks......
I hope you got a couple of refunds in that mess!
well took emissions failed (friday), again, THen tried 4 bottles of heet and octane boost on a 1/4 tank, Failed, Took home that night look over the repair manual and emissions control and check found some cracked hoses and got'em replaced try again this mourning and failed High Hydrocarbs and Carbon Modixide.(not surprised) the car is running to rich damn it. So, i am gonna take to complete auto, But looks like i will have to use The Astro for few days, because can get in til Wednesday mourning (plates expire the 15) I go to college in mishawaka i should just get my plates from there instead put more money into emissions, but I ll show off the flaming van for a FEW days!!o it is FORSALE (Would trade for An FBody!!lol)
One more pic of the Inside just to show off the awsome tv/vcr with AV jacks for video games systems. Not the Coolest Ride, but reliable 4.3 V6
darwinprice
17
Oct 11, 2015 11:51 PM
