Dyno Sheet for my 92 RS
Old Mar 13, 2005 | 11:18 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
Well, here it is, not too impressive, but its a starting point. Here are my modsynomax shorty headers, K&N open element, 1in TB spacer, 3in flowmaster exhausts, and mail-order Hypertech chip.
If you can't see it, max is 171.4 RWHP and 257.8 RWTQ.
I need to do some cooling work(thermostat and fan switch) and do somthing to lean it out on top end. the A/F ratio is at the bottom, its hard to see, on top end my mixture was around 11.5.
Sounds like its time for a new chip...
Kyle
Old Mar 13, 2005 | 01:58 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Fan switch and t-stat. What were you planning? A 170* stat and a 195* fan switch?
Old Mar 13, 2005 | 03:26 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
I'm really not sure, I just know I need it, at the start of a dyno run, it was at 180* and at the end it was 230*
Kyle
Old Mar 13, 2005 | 04:06 PM
vjo90RS8's Avatar
Car: 2002 Z28
you could always wire up a manual fan switch, its really easy, then you can deside when it turns on.
Old Mar 13, 2005 | 07:11 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
I've heard of that Idea, is there a tech article on it or anything?
Kyle
Old Mar 13, 2005 | 07:43 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Looks like you have agreat start there. it would have been interesting to see your AF ratio and power curve with the stock chip. Now would be a good time to look into chip work. I think you would be suprised with the results.
Old Mar 13, 2005 | 07:59 PM
vjo90RS8's Avatar
Car: 2002 Z28
the fan relay is located on the drivers side firewall. All i did was tap into the relay wire which is grounded when the fan kicks on (believe it is the black w/ green stripped wire), ran the wire through a 20 or 30 amp fuse and to a switch, then run another wire from the switch to a ground.
Do a search, there is alot of info about wiring a manual fan switch. Also, if you have a chilton's manual all the wiring diagrams are there and it is really easy to follow. Next time i have the hood up ill take a look and make sure that it is the black/green wire that you tap in to.
Old Mar 13, 2005 | 08:15 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
White/green wire
I made this for another website, but here you go. It's really this simple:
Old Mar 14, 2005 | 09:08 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
Thanks for the help guys , I'll look into the fan switch soon, I gotta do the speedo switch anyways.
Kyle
Old Mar 15, 2005 | 07:25 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
Those are good numbers for an L03 with those mods. I wouldn't be disappointed at all!
Old Mar 15, 2005 | 12:02 PM
SchwarzCamaroRS's Avatar
oh man... 160* T-stat and the manual fan switch was one of the best mods ive ever done... VERY easy...
Old Mar 16, 2005 | 12:03 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
does it offer any performance gains, probly not ad more, but help at the same time, keeping it more consistent, right?
v8nate92RS - thanks man, its about time for a head and cam swap
Kyle
Old Mar 16, 2005 | 07:32 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Benm109 - Why the 5amp fuse.. The green/white wire goes directly to the fan switch on the block, and grounds out there. And there is no fuse in between it and the relay.
Old Mar 16, 2005 | 11:24 AM
Benm109's Avatar
Engine: 305 TBI
The switch I bought recommended installing a 5 amp fuse to protect the switch. I know it's not really necessary, but I did not feel like voiding the warranty (it's not like switches are expensive, though).
Old Mar 17, 2005 | 12:39 AM
Kyle
not any faster or slower or anything... just keeps her a lot cooler while im goin at it... just makes it more managealbe and less scary when you look down @ your temp gague... after a nice drag before, id be about 220... now... im LUCKY if i get it past 180
Old Mar 17, 2005 | 05:47 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
well, I didn't really mean "add power" I meant keep me from losing power, because my engine can't perform its best at 245*, know what I mean?
Kyle
Old Mar 17, 2005 | 10:20 PM
exactly.. it will prevent that.. haha
Magman
Aug 2, 2016 08:32 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
gta892000
Sep 16, 2015 12:37 AM
