Absolute DOG at WOT!
Old Mar 16, 2005 | 04:02 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
I took the Camaro out of the garage for the first time since December today. It was up in my dad's garage in PA and I drove back down to MD. The car was the same when I drove up for storage, but I'll post about it now. Anyway, the car is an ABSOLUTE DOG during WOT. If I start from a stop and shift at 4400 or higher RPM, every gear feels the same. The engine is roaring but the car just feels the same through every gear...SLOW.
Since I bought the car I have done everything in my Signature. I have also replaced the plugs with AC Delco Rapid Fires, Replaced all vaccum lines, rebuilt the TBI, set the timing, replaced knock sensor, replaced O2 sensor, and changed the fuel filter. I don't know what else to do, the car is faster when I slowly accellerate rather than WOT. The car still has a little hesitation when stepping on the gas too. It also struggles sometimes when going up an incline in 5th gear between 40-50mph. Signs point to somewhere in the ignition, but I just don't know what.
I don't know what else to do guys!
Old Mar 16, 2005 | 04:12 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
My friends TBI 4.3 used to be like that too, he sold it before we figured it out.
Old Mar 16, 2005 | 04:26 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Sounds like a fuel issue to me, have you ever replaced the fuel filter or pump? Can you get access to a FP guage and see if you have problems there?
Old Mar 16, 2005 | 04:34 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Is it still the same fuel in the car that you had in it when it went into storage? Maybe it's just choking on the old fuel?
Old Mar 16, 2005 | 05:11 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Excellent point. Although fuel tends to be okay sitting for one winter it can get funky. Either siphon it out, pump it out (via fuel pump bypass), or put some fresh stuff in. I would also change your fuel filter as soon as you know the bad gas is out. Double check your timing as well. If that doesn't cure anything I would look at the fuel system as BMmonteSS mentioned. Make sure both injectors are firing and you may want to test the feed line fuel pressure. Anything less than 10 psi won't cut it
Old Mar 16, 2005 | 07:19 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
I have already replaced my fuel filter before putting it away for the winter. The gas is also fresh, so I know its not either of those. I guess it could be my fuel pump, but like I said, as long as its not at WOT it does fine. Are you sure this couldn't be an electronic issue? Something with the ESC or ECM???
Old Mar 18, 2005 | 11:08 AM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
I guess no one has anymore suggestions?
Old Mar 18, 2005 | 11:54 AM
90RS305's Avatar
Try a bottle of fuel injector cleaner in your tank, maybe you just got a little plugged up and the injectors just can't handle WOT.
Pac J
May 17, 2020 10:44 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Damon
Sep 26, 2015 04:29 PM
