Performer EFI System for TBI
Old Mar 17, 2005 | 03:53 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
I was wondering if it is possible to put on a Edelbrock Performer EFI System in place of my current induction (which is the stock 305 intake and tbi). This efi system uses the same tbi and looks like it would work. I am wondering because i have a built 355 with edelbrock 60cc allumium heads, 10 to 1 compression, the cam is comp 12-256-4 212/218 at .050 and the gross lift is 449/456 . My current setup is not giving me what i really want which is low 13s to high 12s with nitrous. This is the link: http://store.summitracing.com/partde...1&autoview=sku
I am debating on scraping tbi and switch to tpi however i really dont want to do that because of the simplicity of how a throttle body system works. Please someone help me on what to do here.
Old Mar 17, 2005 | 04:26 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Do a search for it, there's a lot of info on this board about that. It's not the best option. Too expensive for what it's worth. TPI would choke that engine too, so don't bother spending the money to do that.
You're options are either get a good TBI intake and run a Holley 670 or 454 TBI and get into tuning PROMs to get the calibration right (ie. start reading the DIY PROM board).
Get a good carb intake and use a setup much like that of the Edelbrock by getting injector bungs welded into the intake and use your TBI on top for airflow and 8 injectors and swap in a 730 ECM.
Or...Get some aftermarket induction that's worth the money compared to the Edelbrock like a converted LT1 intake, Stealthram, Superram, Miniram. Something like that, you could go with a Commander 950 ECU or just swap in a GM 7730 ECM again.
Basically, all your options are going to involve tuning the computer for the combo. If you dont' want to tune it, carb it.
MustangBeater20
Oct 29, 2022 09:20 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Dwayne614
Sep 28, 2015 08:33 AM
beachrodder
Aug 25, 2015 08:05 AM
zayne0
Aug 24, 2015 07:22 PM
