Non EGR intake gaskets with EGR heads
Old May 16, 2005 | 05:18 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I was wondering who runs non EGR intake gaskets with EGR heads. They are a few bucks cheaper and I don't plan on keeping EGR here much longer. I am only getting rid of it for astheitc reasons and I will take care of it in the chip. I figured I would just block off that cavity in the heads and be done with it. I just thought I would try a different intake gasket kit for a change and saw these when i was part shopping. Thoughts?
Old May 17, 2005 | 05:15 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The gasket would have to cover the entire port in the intake and heads with ample overlap, or itll leak air/exhaust. There may also be heat problems as there is exhaust there where the paper gasket is exposed. If it seals, though, it likely wouldnt be a problem IMO. Also, dont forget the block-off plate
Another thing Ive heard of people doing is filling the egr ports in the heads with red hot molten aluminum. Not something you can do on the car, obviously, but If I had egr heads and I had them off for some other reason, Id consider it.
Old May 17, 2005 | 05:26 PM
steve8586iroc's Avatar
The intake gaskets Shifty is talking about has a metal block off plate made into it. You also have the option of knocking it out if you wanted to keep your egr.
Steve
Old May 17, 2005 | 06:56 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Steve
Excellent info. I was wondering about that because I feared what Dimented mentioned. I may just keep it but I like the looks of a clean TBI install. I will most likely fab up my own block off plate since it appears jegs stopped selling theirs. Thanks guys
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
drathaar907
Aug 6, 2015 04:20 PM
