Throttlebody spacer ?
Old May 21, 2005 | 01:21 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Would a throttlebody spacer still be useful and good if I would install a ram air intake on the TBI first ?
Or would the spacer just be a waste due to the increased airflow of the ram air ?
I can see how a regular spacer, raising it, cooling the temp, adding more space for the air... would work excellent with ram air, but my main question is ... the spiral spacers, creating the vortex, would they still be good to buy if one will have ram air ?
Old May 21, 2005 | 04:58 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
By ram air you mean cold air induction or are you actually adding more pressure beyond atmospheric, CAI right?
Old May 22, 2005 | 08:46 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Spacers aren't worth it until you are trying to tune your combo around a few more cubes of plenum volume. I would put the $70 elsewhere.
Old May 22, 2005 | 11:37 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
ram air hood
Actually I'll probably have a ram air scoop .. so that's why I was wondering.. because at higher speeds I'd think the pressure would increase somewhat (depending on where exactly scoop opening would be located on the hood)
Old May 22, 2005 | 05:31 PM
Car: 91 Camaro RS
Re: ram air hood
You should do a search on this, you might be surprised.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
