How much HP? ANY ideas to help?
Old Jun 1, 2005 | 08:47 PM
blackdemon89ta's Avatar
I have a 305
edelbrock manifold, k&n filter open element
Ported throttle body
hedman hedders longtube with 3" flowmasters exhaust
3.73 gears
i want to add 081 heads ported and a cam not sure but probably the lt1 cam setup. ANY IDEAS that i'm doing something wrong and how much HP am i making, i want 300 to the wheels so i need some help.
Old Jun 1, 2005 | 09:05 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: How much HP? ANY ideas to help?
Originally posted by blackdemon89ta
I have a 305
3.73 gears
You have about a solid 200 at the wheels right now. An LT1 cam is a great choice for untouched stock GM cast heads. Before you add the cam I would look into chip burning. Chip tuning is the key to making power with these cars and you are at the point where you could benifit from it. I would take a stab at it now before you get over your head tuning a cam swap. Check out the DIY PROM board to get started.
By the way, TGO welcomes you
Old Jun 2, 2005 | 09:35 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
for 300 at the wheels your gonna need aftermarket heads, and a pretty big cam. Or more cubes and a decent sized cam and decent heads (vortec or the like)
All of which will require major chip tuning like shifty said.
Welcome aboard!
Old Jun 2, 2005 | 11:00 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
I have the secret to 300hp to the wheels....
Old Jun 2, 2005 | 09:17 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
2 Subs and a fire extinguisher?
Old Jun 2, 2005 | 09:51 PM
f_body_4_life's Avatar
Car: 1988 formula
Engine: 93' LT1 Swap in progress..
lol i think im going to copy your secret
Old Jun 3, 2005 | 02:02 AM
SchwarzCamaroRS's Avatar
or... if you want to invest the time... find all the small parts you need used and build from there... you can find a used L98 motor which is a 350 with a somewhat decent set of heads (083's) and a mild cam in it... add an LT1 cam or and LT4 cam with some head work done, or even just better heads and youve got 300hp no problem... all for under 1500 bucks if you do it right...
Old Jun 3, 2005 | 02:04 AM
i want bigger cubes but i got scared to do an engine swap i just put in a t-56 from a 93 after blowing the th700r4 and it was a pain especially doing it in my front yard. so i think i'll just stick with what i got for now and just get the most i can out of it, i've looked into chip tuning but i want everything done before i do that so i won't have to tune it again. i just want this little 305 to keep up with some ls1's and just kill the 5.0 stangs the stangs out here like to talk about how they only have a 302 so being a 305 they can't say it's cause i have a 350.
Old Jun 3, 2005 | 02:10 AM
haha, good luck my friend... if youre going to get a 305 to keep up with an LS1, you had better have lots of time and money... while a 5.0 mustang is a 302, it still has a 4" bore and direct port injection... you, well... dont... i dont mean to be the one to discourage you, but your goal will be difficult and expensive (much more difficult and expensive than doing a motor swap...)
just my
Old Jun 3, 2005 | 07:41 PM
steve8586iroc's Avatar
After you have finished all your motor mods you need to lose about 500lbs to 700lbs just to be in the same leage as a stock 5.0 Stang.
Steve
Old Jun 4, 2005 | 02:06 AM
yeah the 305 just sucks, but everything is still in the air of what actually is going to happen it just a matter of time and money.
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
