timing and heads
Old Jun 15, 2005 | 11:09 AM
Casey_Butt's Avatar
timing and heads
I was just wondering how much spark is typically added when going from swirl port heads to non-swirl heads. Perhaps a hard question to answer accurately, but I'm curious as to how much less timing the swirl-port heads require ...a ballpark figure. Thanks.
Old Jun 15, 2005 | 11:21 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
The factory used 6 deg more base advance on the non-swirl TPI heads than they did on the swirl TBI heads.
EDIT: GM did this because the swirl causes the flame to travel faster on the swirl-port heads, so not as much ignition advance was needed to make optimum power. That's according to the Chevy book, published by GM, on Chevy Powerfor v6s and v8s. GM also referred to the swirl port heads as being "fast burn" and efficient both from emissions and economy.
Old Jun 15, 2005 | 11:28 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
they had a diffrent cam profile though. It is really a mix of a lot of diffrent factors. basicly as the effeciancy of both air/fuel deliver and combustion chamber design, mixed with the atomization of the charge, will all effect timing.
Old Jun 15, 2005 | 08:39 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Found out the hard way that 081s like 6* initial advance more than a stock TBI 305.
Not all TPI had the good cam though. Many had the TBI peanut cam with the only change being the TPI and 081s.
midge54
Dec 27, 2019 04:14 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
ZsTransAm
Aug 11, 2015 07:30 PM
