rich or lean?
Old Jun 24, 2005 | 11:48 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
rich or lean?
how do i tell if my car is running rich or lean? Is it as simple as hooking up a fuel pressure regulator?....will that work?
Old Jun 24, 2005 | 11:52 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Take a DMM and measure the O2 sensor voltage. Under .45 is lean and over .45 is rich. Roughly .45 is stoichiometric.
Old Jun 28, 2005 | 09:59 PM
DeanHensler's Avatar
What is a DMM?
Old Jun 28, 2005 | 10:03 PM
SchwarzCamaroRS's Avatar
digital multi-meter... measures voltage, amperage, ohms and tests diodes.. some even to temperature
Old Jun 28, 2005 | 10:15 PM
Where can I get one? I hooked up a laptop through an ALDL cable using Datamaster and it shows that I'm running lean, but I don't really trust that because I don't know how to interpret the data very well.
Old Jun 29, 2005 | 12:10 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Look at the O2 volts in datamaster. Higher then .450 is richer then ~14.7:1, less means your leaner then ~14.7:1. Other then that, the stock O2 wont tell you much more.
The other thing to look at is BLM data. This can get you pretty close, provided your O2 is working properly.
As for the DMM, radioshack sells them if you want a budget meter. Ive been using one of their fancy ones with a freq. counter, cap. measurement, primitive laptop based datalogger/o-scope, etc. for the last six years and Ive never had any problems with it.
Old Jun 29, 2005 | 08:17 AM
If I send you my Datamaster log would you be willing to take a look at it? I'm not really sure how to read it yet.
Old Jun 29, 2005 | 09:04 AM
Car: 88 Camaro SC
Engine: SFI'd 350
You can also post it on here. If you give it the file extention .bmp instead of whatever it normally has, the server will accept it as a pic and display it as a link in your post. Everyone can then download it, change the extention back, and view it.
Old Jun 29, 2005 | 09:10 AM
Ok, I just changed my knock sensor. I'll do another log tonight and post it for everyone to view and comment on.
Old Jun 29, 2005 | 10:35 AM
Here is one I found that I recorded about a month ago. Yesterday I replaced my knock sensor. Please check it out and let me know what else it shows. I can't figure out how to read this thing!
http://www.4wheelcustoms.com/DeanIma...ressure Up.uni
I'll do a new log tonight as well and post.
F-body-fan
Jan 12, 2023 01:49 PM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
Jk_Under
Sep 8, 2015 08:13 AM
