found somethings on ebay
Old Jun 27, 2005 | 10:18 AM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
was wondering if a tbi spacer would actually add hp/tq? and would an injector spacer add hp/tq? just wondering there only like 15bucks shipped. and the tbi spacer is 40bucks shipped.
Old Jun 27, 2005 | 11:57 AM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
I have not seen any before and after dyno runs of people using either of those spacers, but I think injector spacers work pretty well, especially considering their price. Anything that helps get more airflow in can't hurt.
TBI spacers get mixed reviews. Although, it usually seems like it's too much trouble to install them. Any spacer over 1/2" seems to cause serious throttle linkage and TV cable (on automatic cars) problems.
I'd just get an injector spacer and call it even.
Old Jul 11, 2005 | 10:38 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
instead of buying a spacer for the inj.I just doubled up on the gasket (cheap)and it raised the pod just like the spacer for less money and the gasket doesnt seal anything anyway
Old Jul 12, 2005 | 08:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The injector spacer has been proven to add a few CFM's. I believe kdrolt has the info/links to the flow bench data of a stock TBI tested in this manor. The TBI spacer is another animal. It's design should work but most of us who have them are dissapointed. I have no track times or dyno runs to quantify my dissapointment but the slight plenum increase it provides was not worth the effort to install it.
Old Jul 31, 2005 | 05:03 PM
zeb1999's Avatar
Car: 97 Z, 92 C1500
Engine: 5.7L, 5.7L
Transmission: 6-spd, 4-spd auto
This topic has been beat to death - TBI spacer will help low end performance, but nothing else. TBI injector spacer will increase air flow and offer better fuel cone pattern. The injector spacer can be seen on the link here: TBI injector spacer
Old Jul 31, 2005 | 05:19 PM
bwidner1's Avatar
Car: 1992 camaro rs
Engine: 305 tbi
the tbi spacer is not all that hard to install I have a 1" spacer and it only took about 30 minutes to install, getting the linkage to hook is not that hard once installed opened up the throttle all the way and it should all hook on with minimal effort, and when i did mine bothe the tbi and injector spacer, as well as goign toan open element filter I could actually feel a small low end difference, the big thing is the more mods the more difference it will make due to increased air flow.
Old Aug 1, 2005 | 01:37 AM
NEEDforSPEED's Avatar
blah i hate them, just as useful as buying a tornado, by the way get one of thos tornados i have seen it dyno on a 350 tbi truck picked up 1-foot lb of TQ and drop gas mileage hahahaha useless
Old Aug 4, 2005 | 10:05 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
Dude but it gets off the line faster with extra ft/lb. Joking man lol!!
Old Aug 4, 2005 | 10:34 PM
dwillis's Avatar
Axle/Gears: 3:08
so are the spacers really a joke or just the bs tornado swirl air induction crap you are all thrashing
Old Aug 4, 2005 | 11:53 PM
To be honest with you I don't have any of them and don't know. LOL!! I just thought that the 1 ft/lb addition was the ****. Just joking
Old Aug 5, 2005 | 02:20 AM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
I think an injector spacer is a MUCH better and more logical investment than a Tornado.
Old Aug 5, 2005 | 02:13 PM
Maybe you should get two tornados and then you have like supercharged air going into another tornado supercharger.
Old Aug 5, 2005 | 10:13 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
The TBI spacers are designed to help out up top, larger plenum volume, higher powerband. Do they work for a near stock 305 with crappy heads and weak cam shaft? Not sure, but I'd guess probably not. If your intake wasn't matched well to the H/C package, I could see a spacer helping. Hot Rod's cranked out a bunch of articles on carb spacers:
http://www.hotrod.com/techarticles/2944/index.html
http://www.hotrod.com/techarticles/1...old/index.html
The best TBI spacer is a nitrous plate
Old Aug 5, 2005 | 10:33 PM
Yeah!!! on the nitrous plate that is
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
gta90
Sep 15, 2015 04:00 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
