Bigger TBI ??
Old Jul 5, 2005 | 01:27 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Bigger TBI ??
A throttle body from a BB truck ... i.e. a TBI with 51 mm bore ... and 80 or 90 lbs/hour flow .. would it be a bolt on .. straight .. to a stock intake manifold for the L03 engine ? .. AND .. can one change out the injectors from the 80 or 90 .. to say hmmm 55 lbs/hour ones from the SB pickup ?
Old Jul 5, 2005 | 06:21 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
https://www.thirdgen.org/techbb2/sho...hreadid=205713
That was from the sticky at the top of the page.
Quick answer: No it is not a direct bolt in.
Old Jul 5, 2005 | 06:28 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
No. The bolt-pattern is the same on sbc TBI and bbc TBI so it will bolt up, but the factory sbc intake has bores sized for the smaller sbc TBI so the throttle blades won't open all the way. You will need to bore the manifold bore out to the larger size, and yes, it has been done before.
The BBC injectors will work, that's also been done, and they'll also fit into the sbc TBI but if you do that the engine will run waaaay too rich because you don't have a 454. So you will need to reprogram the injector constant within the EPROM (the chip) of the ECM. If you don't know how to do this, you need to read at lot on the DIY ECM board here at TGO.
Yes, but then again if the ECM (chip) you have was expecting something other than 55 lb/hr, then you'll need to change the injector constant.
Old Jul 5, 2005 | 07:36 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
It would fit, and you could make the motor run well with it, but its too large for an L03. Youll find that itll make the motor harder to control since youll be at WOT by the time the gas pedal is only half way down to the floor.
Old Jul 5, 2005 | 03:01 PM
Ronny's Avatar
and getting the accelleration enrichment in line(tuned), (aka. pumpshot) will be a nightmare.
Old Jul 5, 2005 | 05:53 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
So
So what's my best option otherwise .... bore out the current TBI just slightly ?
Old Jul 5, 2005 | 08:41 PM
Dewey316's Avatar
Car: 1990 Camaro RS
or keep the stock one.
judging by the list of modifications in your sig, I don't see a need for a bigger one.
Old Jul 6, 2005 | 12:31 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
OK
How far can the current injectors support it all ... because I'm in the process of designing a big ram air scoop intake (using parts from Home Depot lol so yeah not real small) ... will the current injectors still be ok.. or any chance I may run too lean ?
Speaking of which.. fuel ... hmmm may have to do a fuel filter replacement this weekend ... for some reason the car started running sluggish after I was down on almost no gas.. filled up the tank full ... (put in a fuel injector spacer yesterday.. doubt that would have anything to do with it) ... and well... it stalled on me in a parking lot ...
It hmmm let me describe it hmmm ok ... runs a little bit sluggish at very very low speed.. at almost no throttle.. there's like a "gap" ... where the car takes a "break" and then goes forward... so something is getting clogged
How much do shops usually charge for cleaning fuel injectors ?
The car supposedly got Fuel Service.. and Transmission Service hmmm 6000-7000 miles ago... but .. hmmm
Old Jul 6, 2005 | 06:17 AM
Dewey316's Avatar
Car: 1990 Camaro RS
You will be fine with stock injectors, its not going to add that much more air. I know for a fact the stock injectors and regulator can support over 200rwhp.
as for your hesitation, i would hook up a fuel pressure gauge, and go drive it, i bet we see your fuel pressure drop when you mash the loud pedal.
Old Jul 6, 2005 | 07:35 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
PROBLEMS
OK... tried it again today....
Once I got home I decided to do a quick investigation .. regarding the problems
It seems like the car's idling pretty good in Park ... when ya switch to Reverse .. or Overdrive (possible Drive as well, but since one moves through OD .. well.. shrugs) ... the idle becomes more rough
It was actually worse after the car had been parked for quite a few hours at work
Do I lack a bit of power uhmmmm well... yes a little bit I think so
So.. suggestions ?
Fuel pressure ... vacuum leak .. throttle position sensor .. idle control ??
It drives ok once out on the road ... but it does feel like a tiny bit less power than usual ... now I doubt the fuel injector spacer would have anything to do with it
Old Jul 6, 2005 | 09:45 PM
Dewey316's Avatar
Car: 1990 Camaro RS
If it is doing funky things at idle, i would look at a vacume leak first. As check your timing, make sure it hasn't slipped.
Old Jul 7, 2005 | 12:27 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
thanks
I'll replace all the vacuum lines tomorrow ....
damn it lol.. did it again... clicked new topic rather than reply lol .... my reply to this one was called.. timing .. hmm something lol
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
sjorgens
Oct 1, 2015 07:54 PM
Gordonr1973
Sep 29, 2015 11:59 AM
