So apparently a 454 TBI and a Stroker do Mix...
Old Jul 14, 2005 | 06:58 PM
TWICEtheRICE's Avatar
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
I just got my engine finally in and 98% of all the components in (still gotta wire the heated O2).
I bolted on a 454 TBI unit onto my 388 (4.060x3.75) with 200 cc heads (Dart Platinums 2.02/1.60) and 72cc chambers. I am running a TBI cam about 218/224 .454/.464
Today I just pulled her out and did some data logging on the stock chip (for the first time)
I did a light accel log and a WOT log.
Under light accel (9.4% TPS) the BLMs chilled at 128.
At WOT she pulled real hard and the O2 read <.930
I havent read the plugs yet though.
My only concern is the AE(right?), when I punch it, it just bawgs (<-- help me)
Old Jul 14, 2005 | 10:49 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
It could either be too much/too little AE or some combination of that with knock counts being picked up by the knock sensor. This will cause the computer to pull alot of timing.
Speaking of that, that reminds me .
If you are having trouble with detonation on tip in, there are some things in the computer that can agrivate the problem. In the 8746, there is a transient delta rpm SA correction table as well as the launch mode logic. The transient RPM SA correction table goes from -200 - 200 RPM. This is shown as 0-400, but I beleive its the former. Basically with that one the computer subtracts timing if the engines rpms are dropping and adds timing if the engines rpms are rising. This may make the motor more responsive to change. What it seems to do is just make the engine run unpredictably. There is also the launch mode logic that adds timing in when the car is first starting off to help get the tc spun up and get the car moving. This one could also cause problems if it pushes the SA past what the motor likes. Zeroing the base SA (LD1CC) for launch mode and the transient rpm SA (LD1E6) might make the motor run more predictably while your trying to tune it. I think these can be useful, but they seem to be a pain in the butt when your trying to get everything else worked out.
Heres those tables from RBobs hac.
Code:
;* 2d lkup
;* Base SA for Launch Mode SA vs delta map
LD1CC:  FCB       0     ;
;		SA	; delta map
	FCB	 64	;   0
	FCB	160	;  10
	FCB	224	;  20
	FCB	255	;  30
	FCB	255	;  40
	FCB	255	;  50
	FCB	255	;  60
	FCB	255	;  70
;* MAP mult for Launch Mode SA vs s/d map cnts
;* tbl = mult * 256
LD1D5:
;		mult	; s/d map
	FCB	  0	;  20
	FCB	  0	;  25
	FCB	  0	;  30
	FCB	  0	;  35
	FCB	  0	;  40
	FCB	  0	;  45
	FCB	  8	;  50
	FCB	 14	;  55
	FCB	 14	;  60
	FCB	 14	;  65
	FCB	 14	;  70
	FCB	 14	;  75
	FCB	 14	;  80
	FCB	 11	;  85
	FCB	 11	;  90
	FCB	  9	;  95
	FCB	  9	; 100
;* delta tps & rpm SA term mult vs delta rpm / 25
;* Indexed Lookup vs delta rpm/25 value
;* SA mult of next table
;* tbl = mult * 64
LD1E6:
; 		SA	; delta rpm
	FCB	240	;   0
	FCB	243	;  25
	FCB	246	;  50
	FCB	248	;  75
	FCB	250	; 100
	FCB	250	; 125
	FCB	250	; 150
	FCB	250	; 175
	FCB	  0	; 200
	FCB	247	; 225
	FCB	  6	; 250
	FCB	  8	; 275
	FCB	 10	; 300
	FCB	 13	; 325
	FCB	 16	; 350
	FCB	 18	; 375
	FCB	 20 	; 400
;* delta tps & rpm SA term vs rpm / 25
;* 2d lkup w/upr limt in 1st tbl entry, lwr limt in B
;* by rpm / 25
LD1F7:	FCB	128	; uppr rpm/25 limit
; 	Mult 		; rpm
	FCB	 96	;  400
	FCB	 96	;  800
	FCB	 96	; 1200
	FCB	 64	; 1600
	FCB	 48	; 2000
	FCB	 32	; 2400
	FCB	 24	; 2800
	FCB	 18	; 3200
;* IAT mult for Launch Mode SA vs iat adc cnts
;* tbl = mult * 256
LD200:	FCB	  4	; line cnt
; 	Mult 		; iat
	FCB	  0	; 200c
	FCB	 64	;  80c
	FCB	176	;  48c
	FCB	255	;  23c
	FCB	255	; -40c
Old Jul 14, 2005 | 10:51 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Oh, BTW, youll also need a WB-O2 to tune the AE. The stock sensor wont really be of much use.
Old Jul 15, 2005 | 05:31 PM
I did another log and I went for about 5 minutes cruising lightly and getting up to about 60 mph. Then I turned around and I got up to about 30 mph at 18% TPS then let up and wopped to WOT. I went from 1 knock count, to 35 at that quick snap of the pedel. Also at the end of the log, I revved the engine before I shut if off and got about 23 knock counts from that.
I did a couple more stop and WOT runs, I did one where I gradually went to WOT(traction problems ) and got 1 knock count (probably headers or something). The other was the same no knock (1 count).
I was mistaken about the car running perfect, it is running a little rich, on the long and steady cruise at 60 mph my BLMs were around 118-121.
From what I could understand from your reply, I am having a computer timing issue, because my understanding is rich does not cause knocking.
Should I force Open Loop (disconnect O2) and try WOT runs, should I retard base timing, or I can't think of what to dooo.
Old Jul 15, 2005 | 05:48 PM
Car: 88 Camaro SC
Engine: SFI'd 350
The o2 is out of the loop in WOT. One thing you may want to look at is the %TPS threshold for PE. This may be a bit high for your motor. Id try to get into PE by the time the MAP is around 75 kPa or so.
Id say its a possible timing issue, or a lean issue, or some combination of both. The stock O2 and the slow datarate may mask this. Id start with the timing and VE tables before you get into the AE. The ammount needed changes as the timing and VE changes.
As for those above tables, Id definatly zero them out if your picking up knock on tip in. It may be false knock, but either way its better being safe then sorry.
Old Jul 15, 2005 | 06:59 PM
Thanks man, i'll see what i can do about that TPS enable and what not.
junior419
Apr 7, 2025 11:35 AM
Nervous2
Oct 8, 2015 10:53 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
