Sensor
Car: 1992 Firebird
Engine: 305 TBI -Tricked Out (320HP and counting)
Transmission: A4
Sensor
What sensor is on the passenger side head with the single post in the center. My buddy broke it off installing headers and now I bought a temp guage sensor but it doesn't fit. Thanks
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
it is the fan switch. It is a coolent temp sensor, that switches the fan on.
(I assume you are talking abotu the sensor between the #6 and #8 cyl.
Car: 1992 Firebird
Transmission: A4
Thanks. That is the sensor I am talking about (between 6 & 8). I appreciate your help. I will go and buy the correct sensor tonight!
Car: 1992 Firebird
Transmission: A4
Wrong Sensor
I went to the parts store and looked at the sensor for the fan switch as well as the coolant temp. sensor. They both had the wrong connection on them. The one I need is between the 6 & 8 cylindar on on the passenger head but it only has one pin in the middle. It also has a round plastic connector around the pin. Anyone know what it is?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by Benm109
Yep, it is definitely the fan switch. Looks like this, right:
Car: 1992 Firebird
Transmission: A4
THANKS GUYS!
That is the one. I will print the picture and take it with me. I will make sure they give me the right part this time. My car thanks you
. Supreme Member
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The only other sensor in the head is the one for the temp gauge in the cluster. This one will be smaller and have a round brass terminal on the end of it. If they hand you this one instead of the F/S that you want, at least youll know what it is. Also make sure that the F/S you get has 3/8" NPT threads. Some older sensors and what not may have 1/2" NPT threads. Doubt this will effect you but you never know what the guy behind the counnter will hand you.
Car: 1991 Camaro Z28
If that is the fan switch, what is the sensor b/w cyl 1 and 3. I don't have a plug that will go the fan switch but i had a sensor there that also looked broken off.
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
b/w cyl 1 and 3
Car: 1991 Chevy Camaro
Engine: 305 TBI
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Could be broken, my connector also broke when I pulled my motor, I think something smashed it against the header. Look around that area or under the manifolds for a loose wire, probably it.
HoosierinWA
Oct 7, 2015 10:15 AM
