Two coolant temp sensors?
Old Aug 8, 2005 | 04:52 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
hey, i noticed the there are two coolant temps sensors, one on the block under the passenger head and one on the intake right up front, whats the deal? why have two unless im mistaken.
i know one runs the fan but which one runs the temp gauge?
Old Aug 8, 2005 | 05:23 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
There's actually 3.
The one in the intake is the coolant temperature sensor. It's what the computer uses to read coolant temp.
The one in the passenger side cylinder head in between the #6 and #8 spark plugs is the coolant fan switch. It's what turns on/off the fan when the coolant reachs a certain temp. (stock switch closes at 238*, IIRC).
The one in the driver's side cylinder head in between the #1 and #3 spark plugs is the the coolant temp. sending unit. It's what the gauge in the dash uses to read coolant temp.
Old Aug 8, 2005 | 06:47 PM
weberflorida's Avatar
Car: 1991 Camaro Z28
Right on dude. Hey man I don't have the one between 6 and 8. I can't even find the wires. I noticed that my fans just pretty much run all the time. Is there a way to fix this or what?
Old Aug 9, 2005 | 12:37 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
hmmmm
What ya run at anyway ? 190 F... 200 F ? Just curious since you and I are in the same city lol
Old Aug 9, 2005 | 08:10 AM
Benm109's Avatar
Engine: 305 TBI
Yes, you just have to figure out which way the previous owner decided to do that. For some reason, people used to think it was a good idea to have the fan run all the time.
I would take a really close look at the wiring from the fan relay, especially the green/white wire. If it's grounded anywhere, the fan will run constantly. 2 common way I have seen people cause the fan to run all the time is to either remove the connector for the fan switch or the AC pressure switch and ground it.
Old Aug 9, 2005 | 11:30 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
dont think i ever saw a sensor or unit on the driver side head, have to look for it. So ive had a finicky temp gauge for a year now. assuming i have no gauge problems my next check would be the sending unit?
Old Aug 9, 2005 | 06:11 PM
Dude it basically gets no hotter than 160. I mean it runs great even though I don't have the temp sensor. I probably will just keep it the way that it is.
Old Aug 9, 2005 | 06:48 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
I wonder
hmmm now that makes me wonder... how cool would one run .. here in SoCal .. with no thermostat.. but everything else .. stock
Old Aug 9, 2005 | 09:12 PM
Dude probably pretty good. The weather here is amazing man.
Bill
Old Aug 9, 2005 | 09:15 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
if you remove the thermostat and the fans run all the time wont that confuse the computer and make the car run rich all the time?just wondering if anyone has input on that....i was told not to put a low temp stat in a stock car because it would cause the car to run ragged and never warm up to what the computer is looking for to make other componets work properly...
Old Aug 10, 2005 | 10:44 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
K lots of questions but no answers
Old Aug 10, 2005 | 05:04 PM
Right on man we need some answers
Old Aug 10, 2005 | 05:23 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
for mine theres always the possibility that i have a 160 degree thermo and it just doesnt get hot after that,,, seems slim.
if i have a stock thermo i know my gauge is running wrong because it just stops at 160. i put in another sending unit last night that i cleaned all the corrosion off of it and it made no difference. i have a fan switch wired up and i use it but an accurate guage would certainly help.
Old Aug 10, 2005 | 06:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Dudes...what is the actual question?
Original post was answered...
Are you dudes asking how cool a SBC will run without a Thermostat? Are you asking if emissions will be affected, or are you dudes asking something else?
Notice the "dude" thing...funny, I can see that coming up in normal conversation, people get into a habit of speech and don't really realize what they are saying.
But c'mon....when your brain has to transfer the message to your fingers, and you have the ability to preview your post and even edit quickly after posted...does "dude" really work?
Maybe I'm getting old, whatcha dudes think?
Old Aug 10, 2005 | 10:00 PM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
Information Please
well, now that someone mentioned the temp/fan/coolant sensor (the one on the passenger side between 6 and 8 plug)...can someone tell me about the sensor? regarding issues with using a lower temp sensor, is there any particular "type" to buy, should it keep my engine a little cooler? what is a good temperature range for a lower temp sensor?...any information is appreciated (also, does a lower temp sensor just turn the fan on sooner...is that all it does?)
[Please don't move this Post to "COOLING"...I already asked there and i recieved no response)
Old Aug 10, 2005 | 10:19 PM
Benm109's Avatar
Engine: 305 TBI
That's basically true. If the engine ran too cool, it would never get into closed loop, which would cause you to suffer some MPG and driveability. Basically, closed loop is just when the computer uses the oxygen sensor as an input to adjust the air/fuel ratio and other parameters of the engine. The only problem, is that O2 sensors are not very accurate when cold, so the car has to run for a while and heat up enough. Usually, the exhaust temp. has to be above 600* and the coolant temp. has to be above 160* for the computer to go into closed loop.
That's not saying you can't install lower temp fan switches or thermostats though. Generally, you want an engine to run in the 180* to 220* range, but it's really up to your preference.
The fan switch just turns the fan on or off, according to coolant temperature. When the coolant temp. reachs whatever the switch is set for, it closes (internally) which grounds the wire to it, which kicks on the relay, which kicks on the fan motor.
Most companies out there seem to sell fan switchs in the 200* and 185* range. Both Hypertech and Jet (check Summit Racing or Jegs) make fan switches for our cars for about $40, but their are cheaper ones out there. A quick search should yield some other options.
Here's what I'm using, for example, part number 609-106:
http://www.madvet.com/shop?frame=1.138.944
Turns the fan on at 200*, only costs $13, and is a direct bolt-in for the stock one.
Old Aug 10, 2005 | 10:38 PM
8Mike9
I am glad that you are so much more intellectual than the rest of us. Secondly, sorry if this is how I talk, or type for this matter.
Bill
Old Aug 11, 2005 | 04:54 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
thanks ben that was helpfull dude. ill prob go with what you have thanks for savin me some money
other "dude" im sure the mods can handle the board just fine but really thanks for your input dude, it was helpfull oh wait, no it wasnt,, but it was instructional, oh wait,, nope not that either.. crap what was it? Useless, thats it!
Old Aug 11, 2005 | 04:59 PM
Dude
Old Aug 11, 2005 | 06:08 PM
dwillis's Avatar
Axle/Gears: 3:08
DUDE!DUDE?
Old Aug 11, 2005 | 06:39 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hint, when you go to your next job interview, don't wait for the call back.
Life is full of lessons, I gave you a free one...you'll pay (in your own way) for the next.
"Aww dude, I'd rock at this job"
Bzzt...
Next.
But hey, what do I know?
Happy DuDiNiG!
Old Aug 11, 2005 | 07:39 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
"Dude... Whats Mine Say?"
"Sweet! What's mine say?!"
"Dude!"
"Sweet!!"
"Dude!!!"
"Sweet!!!"
Sorry, just had to post it, haha
Old Aug 11, 2005 | 07:48 PM
dwillis's Avatar
Axle/Gears: 3:08
Listen fella.I was under the impression that this site was a fun place to mess around and joke with people that have the same interests as yourself...i dont have a problem with anyone on this site...but your pushing buttons and its not fair to the people that just want to have fun.....if you dont like it when someone says "dude" then keep it to your self and dont insult a persons intelligence by trying to degrad them with immature responses about "job interviews" and "dont expect a call back" that is so immature...Im not trying to pick a fight.Im simply stating my opinion just as you did, and I'm sure everyone agrees... By the way some of us are mature responsible adults with jobs and dont have to worry about job interviews....
Old Aug 11, 2005 | 08:05 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
That's cool dude.
You like being called dude?
I'm sorry, your right, dude.
You're a dude... a big dude. That obviously can't push a button, because you're a dude, and don't have an issue with being called a dude.
Right dude?
I'll leave the TBI-Dude_forum, and go back to where I belong.
You win, I'm wrong...dude....I'll go back to pushing parts at AutoZone.
Old Aug 11, 2005 | 08:42 PM
Yeah, you are obviously a lot smarter person the the rest of us. Thanks for the life lesson dad. For your information I have a very successful and promissing career defending your country. So I think that when I am not in my work environment I should be able to speak in whatever context I see fit. Just for your information I am fully aware of the life lesson that you thought was new news for most of us.
Thanks for the insight though...
Old Aug 11, 2005 | 08:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Glad to have helped...
You're welcome.
*** bless if you get deployed.
Old Aug 12, 2005 | 11:11 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
I find being interrupted to be more offensive then being called a dude, thank you for jacking my thread mikey.
can someone here help me with my fualty temp guage? it stops at 160 consisitantly and i dont have test equipment to see if the voltage drop is in the wire. ive heard the temp guage itself can be the problem but how do i fix it?
Old Aug 12, 2005 | 04:09 PM
Have you thought about just getting an aftermarket one with an a piller pod or something? Because to tell you the truth our gauges kind of suck.
Old Aug 12, 2005 | 04:28 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
in regards to totall cost i think id go with a nordskog or dakota digital gauge pack thats custom fit, they look sweet
Old Aug 12, 2005 | 04:31 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
too freaking expensive, id rather go 14's then look cool. is the inconsistancy in the wiring or the gauge pod or what? this might be the answer to the original question.
Old Aug 12, 2005 | 04:56 PM
To tell you the truth I don't know what it is. I mean for instance my tach is like 1000 off at idle and like 3500 off at the mid range in the rpms. Also my oil gauge is always pegged out. So I went to a 5"tach and an after market oil gauge and am thinking of going with a temp gauge also. So to answer your question don't really know why I just know that lots of people have the same problems with their gauges in these cars.
Old Aug 12, 2005 | 05:06 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
If you have that many problems with your gauges, I'm sure it isn't just because they've gone bad. They wouldn't all crap out at once. Check all the wiring to the gauges, and check all the grounds. I'm sure its a faulty ground or bad connection, fix that and I bet they all work much better. It's just a bit of a PITA to go through the wiring.
Old Aug 12, 2005 | 06:28 PM
Well I wouldn't really know where to start when it came to checking the wiring. Do you mean the ground that are bolted to the back of the heads?
Old Aug 12, 2005 | 06:58 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Just a quick one
Yup.. digital gauges like Nordskog.. awesome.. but ... 500 bucks for a cluster ??
*reading the rest of this post*
Old Aug 12, 2005 | 11:03 PM
Yeah digital gauges are expensive that is why I don't have them!!!LOL!!! I have all analog gauges.
Old Aug 13, 2005 | 02:39 PM
jimp2001's Avatar
Engine: LO3 305 TBI
If part of that post was about me then...
This site is fun, thats why I made that post... To mess around and joke with people who have the same interests as myself. That's good that you don't have any problems with anyone on this site. Explain on how posting a quote from the movie "Dude, Where's My Car?" is considered pushing buttons? I don't have a problem with the word "dude," I saw it like 1000 times reading this post, and it reminded me of a scene in a movie. By making the previos post, I tried to make people laugh... not degrade anyones intelligence.
If not... then ignore this post.
Old Aug 13, 2005 | 08:40 PM
dwillis's Avatar
Axle/Gears: 3:08
I wasn't talking about you at all man.I was talking about the guy that was ******* all us for saying"dude"...you just posted before I could and it made it look as if I was talking to youWe're cool man..just a misunderstanding..I just want to have fun and try to help out when I can,and get help when I need it...sorry if I offended anyone...
Old Aug 15, 2005 | 10:56 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
aight, everyone's feelings taken care of? lol its settled 8mike9 was the prob but i think he left.
k yea i can def see grounds being a prob, i dont really care how the gauge cluster connects to the contacts anyways, it seems a lil iffy. So next step is testing how would i clean those contacts? i cant really use steel wool ill short out the whole dash so,,, options? mineral spirits and a rag? and also i need to check wherever the ground goes to from there, anyone know where the ground for the dash gauges ends up??
Old Aug 15, 2005 | 07:41 PM
dwillis's Avatar
Axle/Gears: 3:08
take a womans fingernail file and cut it to the shape you need...file a little and blow off excess...this sounds gay but go to the womens makeup aisle and look for fileing options...Im married and my wife is missing several files and stuff like that
Old Aug 16, 2005 | 11:54 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Wow.. that prob works too. didnt think about it but you could also fold up some 400 grit sand paper..
Old Aug 16, 2005 | 08:04 PM
dwillis's Avatar
Axle/Gears: 3:08
right but the emery board is already tough enough that it wont bend...and you will be able to grip it better,but the sandpaper willwork also
Old Aug 17, 2005 | 04:41 PM
  #42
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
yea you're right, ill try that after this weekend... car is in my sisters wedding.. gahhh...
Old Aug 19, 2005 | 12:22 AM
  #43
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Sorry, I really need to stop drinking and typing...
Old Aug 19, 2005 | 11:02 AM
  #44
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
lol.. no just wait to drink after the typing then drink more..
Old Aug 19, 2005 | 06:08 PM
  #45
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
