code 24, randomly dies/backfire
Old Aug 10, 2005 | 02:40 PM
dan_o_89_rs's Avatar
Car: 89 camaro rs
Engine: 305 tbi
Old Aug 10, 2005 | 04:42 PM
Car: 89 camaro rs
Engine: 305 tbi
Old Aug 10, 2005 | 10:43 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Code 24 is for the VSS (vehicle speed sensor). Is your speedometer working?
As for the "mooing" sound, I'd try and isolate where it's coming from a little more, just to be sure. Like, opening the hatch when it starts and see if it stops. Or hooking up a fuel pressure gauge and waiting and seeing if it rises when it starts "mooing". It sounds to me like it's the fuel pump, but I have no clue why it would randomly come on like that.
Old Aug 11, 2005 | 06:52 AM
Car: 89 camaro rs
Engine: 305 tbi
Old Aug 11, 2005 | 08:00 PM
Vader's Avatar
"Moo", "fart", "burp", "hum", or whatever you want to describe it as could very well be the tank pressure control valve. Perform a search for it, and see if that's what you are experiencing. It usually happens on a temperature increase after heat soak (shutting the engine off with a hot exhaust, no air moving under the vehicle) causing fuel vapor in the tank to expand and increase tank pressure. A properly operating EVAP canister and tank pressure valve in that system usually prevents that.
When it happens, loosen the fuel filler cap to determine if there is pressure in the tank. That's what I'm guessing.
Old Aug 13, 2005 | 09:32 PM
Car: 89 camaro rs
Engine: 305 tbi
Old Aug 14, 2005 | 12:30 PM
Car: 89 camaro rs
Engine: 305 tbi
Old Aug 15, 2005 | 06:35 AM
Car: 89 camaro rs
Engine: 305 tbi
Fanatic1074
Oct 3, 2022 05:57 AM
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
