hesitation in TBI system! any suggestions?
Old Sep 4, 2005 | 06:11 PM
Ryan Stout's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 700 R4
Axle/Gears: 273 rear end
from a dead stop, sometimes i will start to go and it bogs, is it the TBI system or something else? i need some suggestions!
Old Sep 4, 2005 | 06:42 PM
justlearning's Avatar
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
it could be alot of things to cause some hesitation is it like a misfire or what?? i would start w/ the simple stuff like o2 sensor, fuel filter, and your timing.
Old Sep 4, 2005 | 06:53 PM
Ryan Stout's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
it misfires at times but its only at idle in drive. but the hesitation feel like a fuel problem.
Old Sep 4, 2005 | 07:05 PM
Ryan Stout's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
what is the light on my dash cluster mean when the infl
rest
light is on?
Old Sep 4, 2005 | 08:40 PM
Engine: 305 tbi l03
just means your air bag wont deploy in case of wreak.
Old Sep 5, 2005 | 07:35 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
rest
light is on?
That is the Inflatable Restraint light, letting you know a problem has been detected with the Air Bag system. Whenever that light is on, the Air Bags are disabled.
As far as the hesitation, you need to hook a fuel pressure gauge up to it and see what the pressure is when it acts up.
Also, have you tried checking for codes?
Old Sep 5, 2005 | 03:14 PM
Ryan Stout's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
i will check the fuel pressure, everytime it happens it seems to be after it is warmed up, and i am starting to drive from a dead stop! its kinda confusing but i replaced the fuel filter, the o2 has to be fine, because im not getting any check engine codes! and it only seems to happen in drive!
Old Sep 5, 2005 | 04:23 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
IAC
I had the same exact problem ... could be a vacuum leak but .. sounds more like what I had .. IAC
Remove the IAC .. clean it .. lubricate it.. put it back in
MAKE SURE your IAC wire connector is put in the correct way .. if the tab is broken ... one may put it in upside down or 90 degrees off
Old Sep 5, 2005 | 05:47 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Had the problem - put a little acetone (1.5oz per 10 gallons) in my tank and it's gone away.
That indicates a fuel problem to me. Look down that path for the answer. The IAC might be a good idea, but mines brand new and had the problem your describing, so I'd say continue to look at fueling.
Old Sep 5, 2005 | 07:30 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Fuel lines
Check the fuel lines .... Shifty pointed me to the right direction once regarding that one .... the in line has a white teflon washer ... I replaced my fuel line with one fro mthe junkyard... still and older washer but ... doesn't leak anymore
Also ... these fuel lines have a tendency to get twisted now and then ... due to being hard lines ... check the fuel return line ... may be twisted
Old Sep 6, 2005 | 09:53 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
How long has it been since the car had a good tune up? Does this problem happen when the car is hot and cold? I too suspect fueling but it could be something simple like a bad CTS or O2 sensor. A bad 02 won't always throw a code but will cause your car to run like poo.
Old Sep 9, 2005 | 11:01 PM
ckeene502's Avatar
egr....
92camaroJoe
Jul 29, 2023 07:57 PM
MustangBeater20
Oct 29, 2022 09:20 PM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
