Idel, burn out :( ?
Old Sep 5, 2005 | 09:43 PM
NEEDforSPEED's Avatar
Idel, burn out :( ?
what the hell, i put it in gear and she wants to go! i mean go! i set the RPMs on idle to 1,250 cold, right when i put it in gear the Camaro feels like it got reared and then you hear the tires move for a few secs, even on closed loop at 850rpms same deal, i just don't know what the deal is, i think it might be the shift kit, but anyone else have this happen, brakes etc are newer everything else is good, extpe it wanting to lanch to the next world!!
Old Sep 5, 2005 | 09:51 PM
dan, ok mrs i need help with headers lol....
the idle was at 1500 cold stock, and 1000 closed loop....
Old Sep 6, 2005 | 01:04 AM
weberflorida's Avatar
Car: 1991 Camaro Z28
Man that idle is really fast.
Did I mention that the idle is set really fast?
Old Sep 6, 2005 | 07:13 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
My shift kit will pretty much chirp the tires if I try to put it in gear at the high of an RPM, and I have a 2000 RPM stall conv. You really need to drop that a little lower. If it's still pretty violent at 750-850 rpm, it might just be your shift kit. Only thing I can suggest is a looser stall. You don't have a B&M kit do ya? The one I had was brutal at part throttle, and not that impressive at WOT. Transgo is much better.
Old Sep 6, 2005 | 08:58 AM
i have a transgo, was never this bad before, i know when i had the camaro somewhat stock with the kit, it was fine getting put in drive at 1,500rpmswith out braken lose but whould chearp them in 2nd and just bearly in 3rd at WOT, im going to try to bring them down sometime to day, and see if that works.... other wise im ruleing out the tranny
Old Sep 6, 2005 | 11:49 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Have you checked your TV cable adjustent? If its only harsh in drive and not reverse then thats a good sign its a misadjusted TV cable. You want to set the cable for MAXIMUM tension at WOT. This will ensure there is adiquate tension at idle, and more importantly WOT. If Im not mistaken if theres inadiquate tension with the throttle closed full line pressure will be set.
Old Sep 17, 2005 | 02:04 AM
i fixed it
Old Sep 17, 2005 | 11:27 AM
Right on brother!! What was it?
Bill
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
Logan Bryant
Sep 23, 2015 06:51 AM
CatmanFS
Sep 19, 2015 09:00 AM
Glowsock
Sep 11, 2015 11:09 PM
