possible problem w/ cam
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
k guys i just got the cam in i got from a member here and i cant find the number on it i looked on the end opposite of the dow rod and all it has is a 5 i thought this was where the numbers usually r the only other numbers i can find are right before the first lobe on the dow pin side they read as follows:
GMPT. BC. 13.. . 241. i was under the impresion i was getting a cam from a 94 camaro was i douped or mistakenly sent the wrong part?? thanks for the help guys
John
Spanky00185@yahoo.com
John
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Based on the pcitures that you linked to me in a PM I would say that you have the right cam. You can't say for sure but what you have appears to be a gen II cam. It is a hydraulic roller cam and it does not have a fuel pump lobe. It looks like you will be fine.
Engine: 305 tbi l03
k sound good i just checked my mail and he swears its a stock lt1 cam...sound good i just got worried when i didnt see a casting number on the end. thanks shifty oh and im practicing getting used to my burs etc...and i just washed all the grease etc. off my heads and will start porting my 081 heads sunday. i will also be getting my programmer from moates this weekend. so im on my way
Engine: 305 tbi l03
i will need it..lol ive never ported heads or intalled a cam, intake, or heads...etc...so i will need luck on my side but im having some help from someone who has just not on roller post 87 blocks so i will just take it one step at a time and follow shiftys thread to a t. thanks
John
John
Yes, you have a Gen II LT1 cam indeed, and it is out of a 94 Camaro. This is indicated by the 241 stamped at the end of the code. There were also 242's made, but these were made at the end of 96 and were considered the H.O version. The actual part number doesnt appear on the GMParts cams, so you have to search or google the code listed on the cam.
Engine: 305 tbi l03
got u thanks man whats does the 13 designate?? but thanks u just eased my mine alot!! oh and u said it is a gen II cam it is the stock one right cause i cant run over around 460 lift w/ the heads so a stock cam puts me right b4 this threshold. thanks again
John
John
The cam you have is Stock. The lift for that particular cam and year is .450 and .460, so you should be fine. The stock heads on the TBI 305 in camaros can take up to .480, but wouldnt recommend trying that high. If you have a high mileage engine, then I would invest in some new valve springs. If your engine has 100,000 miles on it, then those springs have never had to go higher than a stock cam, and now, all of a sudden they're going to .460. SO that may be a good investment. As for the #13...no idea:-)
If you havent already, check this out.
Finding, recognizing, and installing a cam
Engine: 305 tbi l03
oh yeah i know what the lift for that cam is i just wasnt sure it was the cam i thought since i had thought all cams have the casting number on the end for the lt1 cam, and i could not find the casting number i found on a list for that year none of them had letters or that format of a number like this cam i got does, if that makes since....i guess i was wrong. becuase that number was not on the end it was right before the first lobe on the dow pin end. and oh yeah i plan on getting some new springs. im weary of goin w/ the z28 springs though because ive heard bad things about k-motion ones and some say the z28 ones are the same way. but they machinist i took them to will be doin the valve job and said those springs are good to .500 lift and that still leaves alot of room so its not like id be pushing them to the max or anything. but thanks for that info i was worried for a min.
John
John
Pac J
May 17, 2020 10:44 AM
