engine stalls when i stop
1990 r/s 305
this car will idle fine but when i stop and sometimes when i turn it stalls. as soon as it stalls i can start it when it is fine. it also stalls when i am in reverse. sometimes when i am in netural and i put it in drive it stalls.
any suggestions?
any suggestions?
Car: 89 RS
Transmission: th350
what kind of fuel pump do you have, i have a mechanical fuel pump and when i al low on gass it will stall and die because of the low fuel moving around in the tank, dont know if it will do that with an eletric fuel pump or not
Transmission: 4L80E/4L80E
A 1990 RS didn't come from the factory with a carb. Has one been put on since?
