What causes the motor to surge w/ accessories?
Old Oct 19, 2005 | 09:03 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
My idle is pretty smooth until I turn an accessory on like the defog or a/c. Then it surges up and down while at idle. Is there anyway to fix this? I was just thinking about this, this morning while sitting in traffic as I found it kind of annoying.
Old Oct 19, 2005 | 05:31 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The VE table in the Prom needs work in the cell the engine is running in perhaps. When I turn the A/C on with my cammed 305, the vacuum drops by about 10 KPA which puts it into a different cell.
Another thing could be a ground issue.
Old Oct 19, 2005 | 10:28 PM
91ChevyRS's Avatar
Car: 1998 Volvo S70
Engine: B5254S Engine
Transmission: Automatic
Axle/Gears: It's a volvo?
Re: What causes the motor to surge w/ accessories?
Thats probably your a/c clutch clicking on and off....its really no big issue if thats the case. When you start it up in the morning let the car warm up for about 3-5 minutes before you take off, and the idle should set steadily....its no big issue and completely normal if it is the a/c clutch.
Old Oct 20, 2005 | 02:04 AM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
If your A/C isn't perfect, then my car used to do that when it was low on Freon. When I got it recharged, it never did it again.
Old Oct 20, 2005 | 05:41 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
that's nice to know it's probably the a/c on mine to i'm guessing as i have the same issue with it as you do it sounds.
plm99
Southern California Area
Nov 16, 2015 05:21 PM
neekolzun
Aug 24, 2015 04:59 PM
APCAMARO
Mar 10, 2001 09:10 PM
Zepher
Feb 20, 2001 01:01 AM
