breather size?
Car: GMC c1500 stepside 1989
Engine: 350TBI
breather size?
hi,
just al small question::
what is the size of our valvecover holes?
i put on a open element and a push-in breather but the breather was too big for the hole.
it was a breather for 1,22'' holes.
the grommet was out and stuck so now i can't drive pffff.
tom
tom
Car: 1991 Chevy Camaro
Engine: 305 TBI
Don't quote me on this, but I think the holes are 1" (don't have stock valve covers to check). I do know that the holes in the grommets for the breather and PCV valve are 3/4". If the old grommet in the valve cover for the breather is good, you could just find a 3/4" push-in breather to use. That's what I had to do.
Engine: 350TBI
Thanks,
i found out 1 minute ago that i must have a 3/4'' breather push-in.
now only a grommet to buy over here in this country pfff
Tom
Tom
Engine: 350TBI
I use the breather now.
I used a course piece to make the breather fit right.
The breather was for the 1 1/4''hole but is looks nice now
i can not post a picture because i have tbi-truck and not a 3rd-gen ,
Tom
Tom
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Tom
Tom
Engine: 350TBI
Thanks,
the sound is with the k&n 14'' much better.
i think that it's running al little better but within 2 weeks i'm going to log the truck again.
i must first make a fuel pump swap to a Walbro255 and a high stall converter.
Tom
Tom
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
wait isnt the breather for the LO3 on the passenger side???
And i was under the impression that we should get a covered breather not an open one?? Whats the deal!?!?
Engine: 350TBI
Maybe you see another hole on the passenger side but that's for the pcv-valve.
The pcv-valve is still there but because i went to an open element i use a breather for my crankcase vent.
The covered breather was because i live in Holland(Europe)and there is little choice between them ,besides it looks good.
Tom
Car: '90 RS
Engine: 377 LSX
Originally posted by ShiftyCapone
Either will work fine.
) so i just want to make sure i got it right:Which of these Breathers will fit:
http://store.summitracing.com/defaul...G-2057&FROM=MG
http://store.summitracing.com/defaul...41-754&FROM=MG
or http://store.summitracing.com/defaul...L-4405&FROM=MG
And what size TBI spacer ring will i need for this open element:
http://store.summitracing.com/defaul...41-752&FROM=MG
Pac J
May 17, 2020 10:44 AM
