cleaning ?
Old Nov 16, 2005 | 06:53 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
cleaning ?
what is the best thing to clean a tb with.I mean i figure tb cleaner but i want some diff opinions than just mine...its off the vehicle and about to undergo the tbi upgrades.
Old Nov 16, 2005 | 07:26 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I just use carb cleaner. Just watch the sensor openings, I try to stay away from them when spraying.
Old Nov 16, 2005 | 08:35 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
In addition to what Bron mentioned I would use a soft toothbrush. Keep carb cleaner away from the TPS and if you get any on the IAC make sure to put a drop of fresh oil on it. Other than that just scrape out the old funk and gasket material. It may be a good time to to a complete TBI/vacuum line rebuild.
Old Nov 16, 2005 | 10:08 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Yup yup
Old Nov 16, 2005 | 10:20 PM
dwillis's Avatar
Axle/Gears: 3:08
thanks guys i plan on replacing all sensors and doing a complete rebuild on it..what happens if i get cleaner on the sensor openings?...thanks again
Old Nov 16, 2005 | 10:45 PM
BronYrAur's Avatar
Engine: 305 TBI
Nothin' if you're replacing them. By "openings" i meant the electrical connections. You should be good to go though cleaning it up and putting new sensors on it.
Old Nov 16, 2005 | 10:46 PM
jandl22's Avatar
Car: 82 White Stock Camaro
Engine: 2.5 151 TBI
Transmission: 4 Speed Manual
I would think you are in trouble?
**Mod Edit**
Old Nov 16, 2005 | 10:49 PM
dwillis's Avatar
Axle/Gears: 3:08
why would i be in trouble
**Mod Edit**
Old Nov 16, 2005 | 10:57 PM
Some carb cleaner is more then likely not going to hurt a thing....
Now heavy-duty degreaser is another story...
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
WhteRbt
Sep 21, 2015 09:48 AM
